#11 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
Don't want to sound negative but i've tried liberating EL84 pentode amps from negative feedback and the results have been quite lo-fi. Anyone been luckier?
cheers peter |
#13 |
perhaps this has still some more elegance:
#14 |
what about this ?
#15 |
Jaap,
1) How are the tubes biased in your push-pull example? 2) What do these designs have to do with the original posting?
#16 |
diyAudio Senior Member
Something is missing there. Cheers,
Frank |
#17 |
The thread is also about simplicity and elegance, but you are right I don't see a el84 in these designs. By the way I have used 2A3, 300B and 6B4 but yesterday I fired a simple 6N1P cap coupled EL84 se-amp. Of course everybody should start with the el84 in the first place. Boy what a good amp is this ! I used a small fourty year old outputtransformer and the amps rocks. Of course no feedback.
here is the powersupply of the PP 6B4: |
#18 |
Mods as per fdegrove;
I don't know if I'd go as far as putting a 470uF cap in the p.s., in that C4 position. Seems to be overkill, and could significantly reduce the life of the 5Y3 and the power tranny. 50-100uF would be more than enough. I guess I've seen a few barbequed amps with hi value caps in the power supply. It's not pretty. If you really wanted it to sing, try using film caps in both positions; say a 20uF for the first cap, and anything or combination of caps (space limitations) at or over 40uF. That would sound even better. Agree with .22 for C1. Play safe; keep one hand on the chassis, one hand in your pocket. jD
jD If it doesn't fit force it, if it breaks, buy another one. |
#19 | |
#20 | ||
If you value awesome dynamic range and deep,solid bass...follow my lead. Quote:
While you're at it you can make an electrolytic cap sound as good as a filmcap by decoupling gradually. Cheers,
Frank |
| 5W EL84 drive EL84 SE | Audio_idiot | Tubes / Valves | 31 | 31st May 2012 08:38 PM |
| NHT 3.3 Modifications | SY | Multi-Way | 22 | 22nd June 2008 05:12 AM |
| DAC-in-the-Box modifications. Again. | Aleksunder | Digital Source | 1 | 19th July 2007 03:10 AM |
| DAC modifications | elaar | Parts | 5 | 29th May 2006 01:11 PM |
| Zen V4 modifications | pro | Pass Labs | 2 | 31st August 2004 05:19 PM |
