diyAudio Sponsor
Old 13th March 2007, 12:14 PM   #1
Talking EC52--Plate choke--300B/45/2a3/50/EL34 SE
hi,
any people had comment for this.
thx
thomas
Old 13th March 2007, 12:18 PM   #2
this tube---
The EC52 is a small transmitting valve from the early days of all glass construction. It was designed for VHF operation, and probably mobile equipment.
The picture shows the............. Flattened oxide coated cathode and the gold grid wire can also be seen.................. The anode is carbonized. The whole electrode assembly takes up less than half of the envelope, and a second valve could be physically fitted into the envelope.
Oh, flattened oxide cathode is large amount of electron emittion & gold grid will better sonic performance.
thx
thomas
Old 13th March 2007, 12:50 PM   #3
phn is offline phn  Sweden
phn's Avatar
http://www.anc-tv.ne.jp/~suzuki3/amp...52_2a3_amp.htm
Old 13th March 2007, 02:26 PM   #4
Hard to find this 9-pin loctal sockets
Andreas
Old 13th March 2007, 05:37 PM   #5
hi AndreasS,
many thanks for your comment.
U right, B9G was not easy to get But I had several hndard on hand. All NOS silver plated & military by British Army.
There will had another method for this tube. Pls take a look for the EC52>> anode choke>>2a3/300B.
Take a look of the bottom of the this anode choke tube kit, very easy to funish.
thx
thomas
Old 13th March 2007, 05:43 PM   #6
hi Phn,
Your advised circuit I was tested already. I work very well but high impendance IT will not easy to get a very good one. Second was all the sound texture was regarding for the IT.
Looks if I use Anode choke still need cap couple & I can cahnge different brand of coupling cap to change the sound nature.
many thanks
thomas
take a look of the circuit.
Old 13th March 2007, 06:02 PM   #7
phn's Avatar
I guess only the Japanese are crazy enough to use ITs as high as 25 and 50k.
The rest of us look for a driver tube with lower Rp.
Old 13th March 2007, 06:10 PM   #8
hi phn ,
agree your comment be sometimes higher plate resistance tube the MF will higher density than low plate resistance such as 5687 & vocal sound was quite attactive.
thx
thomas
Old 13th March 2007, 06:57 PM   #9
Hi Thomas,
IMHO the EC52 is a better choice than the C3m (higher max. plate voltage, higher bias).
What are your experience with the DHT EC52 (microphonics, heather hum)?
best regards
Andreas
Old 13th March 2007, 07:07 PM   #10
Default mistake
sorry, the EC52 is indirectly heatet (I was thinking over DC25)
Andreas
EL34 plate glowing? ultrachrome Tubes / Valves 15 1st June 2011 03:55 PM
6SL7 EL34 300B amp MartinV56 Tubes / Valves 2 1st October 2007 06:21 PM
PP plate-choke? revintage Tubes / Valves 4 28th June 2007 11:59 PM
417A-300B Plate Choke or Interstage Coupled? sgerus Tubes / Valves 21 14th January 2007 12:45 AM
Page generated in 0.11701 seconds (82.15% PHP - 17.85% MySQL) with 10 queries
