diyAudio Sponsor
Old 12th March 2007, 07:47 PM   #1
ghisdal is offline ghisdal  Norway
Default Bias adjustment on Dynaco ST70
Where do I measure the BIAS of this amplifier? The original manual is unclear on this point....
Where does the mulitmeter go?
Old 12th March 2007, 08:05 PM   #2
tangen is offline tangen  Norway
You have two connectors in the front? Each have a hole that is marked "Biaset 1,56 V". Set your multimeter on 2 V. Put the read pin from the multimeter in the hole mentioned and the black pin on the chassis. Take the left side first. Use a screwdriver on the potmeter on the top of the chassis between the valves. Adjust the left potmeter til you read 1,56 V on the mulitmeter. Then move the red pin to the right connector/hole, and repeat the above. I a adjust to only 1,4 V (longer life on the valves, and the amplifier plays better, in mye opinion).
You can phone me, I am a norwegian +47 916 26 170
best wishes
jan ove
DIY Dynaco ST70 wingking3000 Tubes / Valves 2 25th July 2008 10:20 PM
DIY Preamp for use with Dynaco ST70 liggs17 Tubes / Valves 3 7th December 2006 06:46 PM
Dynaco ST70 clone Tekko Tubes / Valves 8 9th April 2005 02:02 PM
SDS power supply board for Dynaco ST70 Mikelo Swap Meet 0 17th January 2005 09:58 PM
Dynaco ST70 cwteoh Tubes / Valves 14 27th May 2004 06:07 AM
Page generated in 0.07411 seconds (70.58% PHP - 29.42% MySQL) with 10 queries
