| diyAudio Sponsor | ||
I have searched the threads but of course the debate rages... Whats the lowdown on SRPP... vs Cathode follower (with regards to a 6sn7 preamp) and what if you convert the srpp into a true ccs? what then. Is this all about cancellation of the second harmonics and harshness (read odd order harmonics)
what are the ads/disads? Thanks for your help Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt." |
#2 |
SRPP has gain; a cathode follower generally has about 1dB loss. SRPP doesn't have the full gain of mu, so it has significantly higher distortion than a mu-follower. The distortion of the lower valve has to be very low before there's any cancellation with the upper valve (effectively a cathode follower), so that means that only mu-followers need apply for cancellation, and even then the effect is barely noticeable.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
They have low output impedance BUT that doesn't mean they can source unlimited current.
/Magnus
| J-fet Zen Srpp ??? | Circlomanen | Pass Labs | 19 | 11th April 2010 09:27 PM |
| Are Srpp's Any Good (please Help) | soundbadger | Tubes / Valves | 6 | 17th October 2007 09:09 AM |
| mu / srpp / or CF? | AudioGeek | Tubes / Valves | 9 | 24th April 2004 05:48 PM |
| SRPP is....? | peranders | Tubes / Valves | 8 | 19th December 2003 08:38 PM |
| Help with SRPP pre- | ktigerb | Tubes / Valves | 11 | 10th October 2003 10:40 PM |
| Page generated in 0.06049 seconds (81.74% PHP - 18.26% MySQL) with 10 queries |
