diyAudio Sponsor
Old 11th March 2007, 04:13 PM   #1
Sal Brisindi's Avatar
Default Broken 6L6WXT tube
Yesterday I accidentally tapped my 6L6WXT tube. I didn't know I broke it until 7 hours later when I went back in my dungeon... err I mean basement. The silvering on the top of the tube faded to a milky white color. How does that happen, does oxygen attack the silver coating? It stuck out like a sore thumb as I have a quad of them all together.
Sal Brisindi
Old 11th March 2007, 04:29 PM   #2
Brian Beck's Avatar
Default Re: Broken 6L6WXT tube
Sadly, that's exactly what happened. The getter flash is usually a mixture of barium and other metals, and when they oxidize they do turn white, indicating that your tube is no longer a "vacuum" tube.
My head is turning white too. I wonder if I'm oxidizing?
Brian
Old 11th March 2007, 05:45 PM   #3
Yes, it means you're getting gassy, Brian.
How do I know this, hm?
Aloha,
Poinz
Old 11th March 2007, 06:30 PM   #4
Brian Beck's Avatar
All the way from Hawaii? Jeez, I'd better lay off the Taco Bell...
Brian
Old 11th March 2007, 06:47 PM   #5
Stay away from Taco Bell completely and stay alive. Every time you turn around, there's another story about E. Coli contaminated vegetables at T/B.
Eli D.
Old 11th March 2007, 08:08 PM   #6
ArtG is offline ArtG  United States
Taco *ell
Old 12th March 2007, 04:33 AM   #7
frank754's Avatar
Not to mention the rats that took over the one in Greenwich Village NY a few weeks ago. But I can't stay away from them, even when home & my wife's away I make the dreaded spicy stuff that wakes you up in the morning too. I'm only being off topic here 'cause you guys started it, lol.
6L6WXT in a Dynaco ST-70 Sal Brisindi Tubes / Valves 12 12th August 2007 11:11 AM
my first broken amp... need help tweak+peak Car Audio 37 18th May 2007 06:54 PM
Broken Tube pin guides audioboy69 Tubes / Valves 3 22nd February 2007 04:54 PM
WTB: CHEAP tube amp. Broken/single channel/whatever. Spasticteapot Swap Meet 4 25th October 2006 11:51 PM
Sovtek 6L6WXT rcavictim Tubes / Valves 1 7th August 2004 01:55 PM
Page generated in 0.08870 seconds (74.91% PHP - 25.09% MySQL) with 11 queries
