diyAudio Sponsor
Old 10th March 2007, 03:10 AM   #1
Default Gated beam discriminator "amplifier"
Any ideas on how I could use a gated beam discriminator tube (6BN6, etc.) to "amplify" a guitar signal? High distortion would not be an issue, in fact, it is desired.
In the immortal words of Socrates, "I drank what!?"
Old 10th March 2007, 03:25 PM   #2
astouffer's Avatar
I played with the 6BN6 a while ago (before I knew what they were used for) and found it can amplify well. It was connected like a normal pentode preamp but the higher the plate voltage the lower the output. Can't recall any part values right now.
Old 10th March 2007, 05:15 PM   #3
aletheian's Avatar
Heck yes. Peter Millet used that setup at the triode festival to bens the transfer function to demonstrate odd vs even order harmonic distortion sound differences. The schematic is on his site. Metasonix also uses one for a little synth distortion box.
Heghlu'meH QaQ jajvam!
"An Adjustment-Free Complementary Power Amplifier" by J.Diamond jez Solid State 28 22nd August 2010 11:33 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
Newbie wants to build a "GainClone-Like" 5.1 Channel Battery Powered Amplifier captain Chip Amps 7 15th October 2004 12:35 PM
Page generated in 0.07492 seconds (68.06% PHP - 31.94% MySQL) with 10 queries
