| diyAudio Sponsor | ||
I am looking for a 250-0-250 transformer (a little higher or lower voltage is not a problem) at 40mA that is low profile enough to fit inside a chassis with 2.25" of clearance (that's 5.7cm). If it has a 5V secondary that is a great bonus, but it is not essential.
Lundahls are too expensive (and I'm not sure they would fit anyway) -- $120 is the ceiling, and even that is probably too high. Am I stuck with a toroidal? Is there somewhere to get this custom made? I would usually use electra-print, but I think they are too large in this case. |
#2 |
Perhaps this toroid (or something similar) would work (about 0.25 " too large)
http://cgi.ebay.com/460V-CT-230V-220...QQcmdZViewItem
"Any fool can know. The point is to understand" - Albert Einstein |
#3 |
When I have a problem finding it on the normal channels, I usually check Allied as a fallback.
This one may work for you, no 5v taps though. Shouldn't be really big with the lower ratings, and only $21: http://www.alliedelec.com/Search/Pro...F0A38074CF617F |
#4 |
Thanks, but it appears to be slightly too large.
#5 |
Hi dsavitsk
Maybe you can work with trafo's wired back to back, http://www.tubecad.com/january2000/page16.html If you can find those low profile trannys cheap, from surplus, it could work out. Off course you will get lots of mass, but hey, you talked about low profile, said nothing aboutthe beed low mass or low area Nice weekend! Erik |
#6 |
I used a toriod kit from Toroid Corp of Maryland for my tube DAC transformer. I wound a 250 volt b+ winding and a hefty filament winding plus +-15 windings for both analog and digital power. It's an 80 va transformer which is 1.7" high and about 3.5" in diameter when finished.
http://www.toroid.com/standard_trans...ormer_kits.htm And some info on what I did with the smallest kit: http://quadesl.com/pdf/trans_inst.pdf Sheldon |
| Profile A1200 XL Odd Power Supply | amc32 | Car Audio | 5 | 26th November 2008 10:44 PM |
| best cone profile for sub ? | ejaouen | Subwoofers | 12 | 17th June 2008 04:28 AM |
| profile A600 2 ch | jrod666999 | Car Audio | 9 | 18th March 2008 10:26 PM |
| Low Profile Desktop Power Supplies | Tom D | Solid State | 11 | 7th August 2003 09:24 PM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| Page generated in 0.09794 seconds (76.28% PHP - 23.72% MySQL) with 10 queries |
