| diyAudio Sponsor | ||
I just finished building an amp from salvage parts designed to run triode strapped 6l6 tubes. After not being very impressed with the veiled sound of those tubes, I tried 6v6, 6f6, and 6k6 types. All sounded better, with the 6f6 and 6k6 taking the edge in terms of clarity. Then, I popped in some 6w6 types that I had. Much better. Remembering an old experiment with similar 6DG6GT tubes, I popped them in the amp and . . .WHOA! With a properly selected driver tube (an unknown 6SN7 tube), this is by far the best sounding amp I have ever heard. It is detailed without being clinical, has beautiful tone, a thick midrange, and three dimensional sound staging. The funny thing is that I have only used junk box parts, except for Auricaps that I had from other projects, and was planning on replacing the E caps and trannys with higher quality parts. I don't see the point now. What I don't understand is what it is that makes an amp "magical". That is, in terms of the circuit behavior, what is the defining property or properties? That term gets bandied about easily, but until I heard this amp, I did not know what it meant--instant relaxation and enjoyment of music with no desire to tweak anything.
I used some (common) design features that I have never tried before, like a separate final filter cap for each output tube, separate transformers for the filament and B+ supplies, extensive bypassing with high quality caps, and lifting the ground with well implemented star grounding (dead quiet). I also have very short signal paths from the input jack to the pot to the first tube with twisted pairs of teflon CAT 5 for signal wire. Also, the tubes are running way above spec but nothing is glowing red. Anyway, I thought I would post the schematic to solicit comments on what might account for the special sound. I wired up the amp without one and reconstructed it today at work, so hopefully I didn't put anything explicitly wrong on it. Thanks for help on my previous few posts. |
#2 |
I built the thing on a DAT chassis for a weird look. The gunk on the front, that I am trying desparately to remove, is hot glue to hold on the drive cover. I forgot to connect the LED on the front to the filament supply. Output transformers are little 2 inch tall jobs that I pulled out of a console. They are mounted inside.
#3 | |
As for making "magical" amps, if I knew how to do that I'd be doing it and putting the forum out of business. |
#4 |
diyAudio Chief Moderator
Is this a 2X165Vac Trafo or 2X330?
#5 |
2x165, so about 350 unloaded for the PS. However, loaded takes the B+ at the tube to about 185. The primaries of the output iron are about 550 ohms DCR.
#6 |
I suggest loading up something like AudioRightmark and magic hunting. In my experience different models of tubes, and different brands of the same model, each have their own distortion signature. You may have stumbled on a sweetheart model/op point. That you noted it's driver dependent also makes me wonder if a little second-order cancellation is happening.
#7 |
I used 12L6 in hybrid amp to drive sand output stage, it is a brilliant lamp as a triode.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#8 |
I've found that the 6W6GT and 6DG6GT (essentially identical) are real "sleepers" as audio tubes. I've used them as driver tubes in transformer-coupled single-ended and push-pull amps with good sucess.
I'm not quite sure why these tubes sound so good, but perhaps because these are identical to the highly-mass-produced 50L6GT, except for the heater, the internal construction is very consistent and not pushed too hard to get high transconductance. Both these factors tend to improve linearity. Just a guess. Anyway, luckily, these tubes are still quite available, since they were used in millions of TV sets from the 1950s and 60s. |
#9 |
I measured the circuit better: Full behavior is -19.5 bias, 185 V plates, and 42 mA draw. I spent last night tube rolling and found that these output tubes were much more important than the driver. "Magic" happens with a few 6sn7s that I have and these 6dg6 tubes but none of the output tubes I have are magical with the current bias and B+. The best combo, though, is with the 6sn7 in the picture. I think it is a Raytheon. However, most of the output tubes I have with that pinout (6l6, 6w6, 6v6, 6f6), sound good and make decent amps. My statements about the 6l6 types being veiled apply more to the older globe types I have. In between those and the present setup are RCA 6l6gc blackplates and nearly as good are GE 6l6GC gray plates. As Miles Prower stated above, the plate voltage is below the design center of the 6L6 types, so I am not giving them a fair shake with this circuit.
The schematic I posted left out a heater lift on the audio tubes of about +70 volts. I don't know if this makes a difference. I like the idea of sytematic magic chasing. One thing I have noticed is that really good amps always soundstage well. All amps that soundstage well do not sound great, however. This one has natural depth and height that I have never heard. In addition it has a believable tonal mixture, and avoids the slightly thin sound that tends to go along with single ended triodes. If it has any weakness at all, the bass response has a resonance (subjectively measured) at about 90hz, so some bass notes in that region boom a little too much. It's not unpleasant, just innacurate. Probably the unknown transformers. I think I pulled them from an old GE console. |
#10 | |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| "magic" phase splitter for SimpleP-P | tubelab.com | Tubes / Valves | 65 | 3rd May 2008 02:13 AM |
| Bit of history.."Magic Brain" record changer | redrabbit | Analogue Source | 0 | 10th February 2008 07:53 AM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.13430 seconds (80.75% PHP - 19.25% MySQL) with 11 queries |
