diyAudio Sponsor
Old 8th March 2007, 04:24 AM   #1
Default Obscure radio tube
I am seeking information about the obscure 8106 tube, as I have recently come across one in an old Narco Omnigator Mk2. Does this tube serve any purpose in audio?
In the immortal words of Socrates, "I drank what!?"
Old 8th March 2007, 04:36 PM   #2
Send a message via AIM to ThSpeakerDude88
here is what I found online
8106--small pentode, used in mobile radio equipment. Equipment could be modified to accept 12BY7 or SV83.
Apparently it has a 13.5v heater, so I would assume a car radio tube or the like. It is listed as a beam pentode on tubesandmore.com. Couldn't find a datasheet online...
always preach the gospel-
and when necessary use words.
Old 8th March 2007, 09:26 PM   #3
Geek's Avatar
I have a couple of those from VHF taxi radios. Yeah, treat it like a 12BY7. Only the plate disspation is 5.5 watts, IIRC, which is impressive for it size!
Looking for curves for obscure tube coldcathode Tubes / Valves 3 12th August 2009 01:19 PM
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
Help - tube radio JDeV Tubes / Valves 49 19th October 2006 08:18 PM
Tube Radio Kit cuallito Tubes / Valves 11 29th May 2004 10:59 AM
Another tube radio Magnetmaz Tubes / Valves 7 11th March 2003 06:01 PM
Page generated in 0.07368 seconds (68.19% PHP - 31.81% MySQL) with 10 queries
