diyAudio Sponsor
Old 10th January 2008, 08:45 PM   #81
Originally posted by salas
I would smack the living daylights out of those luna park 6E2s!
Just wondering Is there a problem with it's Magic Eyes?
Old 11th January 2008, 12:24 AM   #82
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No! Its just humor because I don't like flashy gimmicks on a tube amp. It degrades it aesthetically IMHO.
Old 11th January 2008, 01:22 AM   #83
Not entirely just humour.
On a Music Angel EL34 PP Amp I had, I thought pulling the magic eye tubes (and deleting the associated circuitry) improved the sound.
Ian
Old 11th January 2008, 11:16 AM   #84
Salas's Avatar
Could be drawing some current or reflecting some signal. With good resolution source and speakers, yes it may be a little audible.
Old 11th January 2008, 05:38 PM   #85
Ok thanks, Thing is mine rarely bounce as its loud in our bedroom before they get active! (still talkin about the eyes that is )
Using Mordaunt Short 902i's 89db.
Old 9th February 2008, 05:16 PM   #86
DanDini is offline DanDini  United Kingdom
DanDini's Avatar
I've started to write up my findings on the various Yaqin models I've had here:
http://www.slickpepper.dyndns.org/valve-tube-amps
It's sparse at the moment, but I will add more.
Dan
Old 14th February 2008, 11:48 PM   #87
Originally posted by gingertube
More complex mods:
Make up a little "matrix" board with a cascode transistor current source (or ring of two transistor current source) to replace the 30K/2W tail resistor in the driver stage and make the 2 anode loads the same - both 47K would be good.
Use separate cathode bias resistors and bypass caps for each 5881.
Ian [/B]
Hi Ian, can you explain more of the above? Is there any schematics? Thanks.
Old 15th February 2008, 03:16 AM   #88
Did'nt have time to do much but have scribbled some current sources on a piece of paper which would suit.
Ian
Old 15th February 2008, 07:55 AM   #89
Thanks Ian. Will try once I have my hands on these components. By the way, what do you think of these China tube amp? I've compared with Marantz PM4001 & Aura and I feel that there is something missing in the songs played with 5881. Its like there is no life in it???
Old 15th February 2008, 06:31 PM   #90
Salas's Avatar
See about substituting the stock gray coupling caps with something good, and you will get some expressionism in its sound. Also see for Blackgate FK instead of the stock cathode bias bypass output stage caps.
Yaqin mc10L gasman Tubes / Valves 167 21st May 2012 02:54 AM
Yaqin MC10K ramallo Tubes / Valves 0 22nd January 2009 04:42 PM
Yaqin MC-10L cruzrman Tubes / Valves 0 23rd July 2008 02:37 AM
Yaqin Valve Amplifier UK Sales & Service marktravuk Vendor's Bazaar 3 16th November 2007 04:55 AM
yaqin mc10k inquisitive Tubes / Valves 33 8th October 2007 12:56 PM
Page generated in 0.11716 seconds (80.05% PHP - 19.95% MySQL) with 11 queries
