Yaqin MC-5881A amplifier improvements
Old 24th September 2007, 02:42 PM   #51
DanDini is offline DanDini  United Kingdom
DanDini's Avatar
Yes, it is still audible, more so on the more sensitive speakers I have in the living room (90db as opposed to 88). It's something like 30mv peak to peak. It would be a major cosmetic mod to rotate the mains transformer as it is not square and would not fit within the cover anymore. It must be induced mains as the basic sine is at 50Hz and supply ripple/ac heater noise or similar would be at 100Hz, no?
Dan
Old 24th September 2007, 04:01 PM   #52
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Supply ripple sure is 100Hz, but as I recall your heaters are AC fed, so still 50Hz for them. If we assume that your GND loops are all gone by now, it can be an electromagnetically induced residual that you pick up, or at least the best part of it.
Old 25th September 2007, 03:41 PM   #53
DanDini's Avatar
I set this up last night in my daughter's room. It's quiet in there (when she's not around). I was surprised that actually the noise was mostly inaudible. I need to try it with other speakers, but overall the sound was enjoyable. It's actually got quite an involving feel and Eva Cassidy came over well at first listen. I'm not expert at describing sound quality, but I will arrange a listen with a friend of mine who is, so expect more to come.
Old 25th September 2007, 03:43 PM   #54
Salas's Avatar
If you replace those gray coupling caps with something better you will have a lot more to listen to.
Old 27th September 2007, 08:10 PM   #55
DanDini's Avatar
One thing I didn't consider in lifting the ground between mains earth and the input is that other devices which are earthed reintroduce the loop. My original testing was with a battery powered cd player - no earth. It also works fine with my marantz cd player - again no earth as it is 2 pin only to mains.
How best do you think I can earth the input so that connecting other devices with three pin plugs don't cause a massive hum?
Thanks,
Dan
Old 27th September 2007, 08:26 PM   #56
Salas's Avatar
By braking with a 10R.
Old 27th September 2007, 09:24 PM   #57
jnb is offline jnb  Australia
Connecting to safety earth is OK. Connecting at multiple points is the problem.
Old 1st October 2007, 09:10 AM   #58
zapp is offline zapp  Singapore
Just got this amp from ebay. It runs hot like crazy - any chance of how to do the resistor thingy for someone who has ZERO electrical/electronics experience...?
Old 1st October 2007, 09:32 AM   #59
Salas's Avatar
I would advise you to print out page 1 of this thread with my instructions for lessening the heater voltage and dropping the bias, and off you go to your nearest TV repair guy or some other technically adept fellow. Its very easy for someone who has put a couple of circuits together before. You STAY away! Lethal voltages inside, even when not plugged to the mains.
Old 1st October 2007, 11:54 AM   #60
hi salas - tks for the reply. yes i will take your advice and leave the physical handling to the pros lol.
Yaqin MC-5881A amplifier improvementsHide this!Advertise here!
Yaqin mc10L gasman Tubes / Valves 401 1st February 2017 09:35 AM
Yaqin MC10K ramallo Tubes / Valves 0 22nd January 2009 04:42 PM
Yaqin MC-10L cruzrman Tubes / Valves 0 23rd July 2008 02:37 AM
Yaqin Valve Amplifier UK Sales & Service marktravuk Vendor's Bazaar 3 16th November 2007 04:55 AM
yaqin mc10k inquisitive Tubes / Valves 33 8th October 2007 12:56 PM
