| diyAudio Sponsor | ||
Is there such a thing? A dual 9-pin triode with the same characteristic of the 417A?
Tube gurus, I will appreciate your recommendation. TIA |
#2 |
diyAudio Moderator Emeritus
I don't know of an exact match but the specs of the 417A are unusual, to say the least.
The closest I can find are 7044, 8223 and E288CC. None of these has such a high amplification factor or transconductance as the 417A but they are within the ball-park for plate resistance, plate max. dissipation and plate max. current rating. All are 9-pin double triodes. |
#3 |
hi ray, thanks so much for taking the time. much appreciated.
| using only 1/2 of a dual triode | gabriel611 | Tubes / Valves | 18 | 2nd July 2010 06:43 AM |
| 6H30 Dual Triode | GlidingDutchman | Tubes / Valves | 9 | 10th July 2008 10:50 PM |
| Recommend an input stage triode please | zigzagflux | Tubes / Valves | 20 | 16th April 2008 03:42 PM |
| Page generated in 0.06571 seconds (68.20% PHP - 31.80% MySQL) with 10 queries |
