| diyAudio Sponsor | ||
All,
I received a couple of transformers, and I'd like to know the specs on them. I've measured the voltages, etc; but now I'd like to know what sort of amperage I can expect out of the unit. What is the best way to go about this (while staying in the land of the living...) ? Thanks ! Steve |
#2 |
Here's a page with some useful charts: http://geek.scorpiorising.ca/windingtransformers.html Find the approximate VA of the core by the size. Then if you can see the wire, at least one winding, you can derive the rest pretty much from math. Cheers! |
#3 |
Very cool - I'll see what I can come up with this evening !
Thanks again, Steve PS - On one of my transformers, it is potted - so this solution is not going to work.....Any suggestions then ? |
#4 | |
I usually load all secondaries until voltages on them drop on 10% then calculate.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
| Determining ratings for unknown Power Transformers | boywonder | Tubes / Valves | 3 | 22nd April 2009 10:27 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| amplifier for unknown output transformers? | tonskulus | Tubes / Valves | 20 | 9th December 2007 11:36 AM |
| Evaluating Unknown Power Transformers | wrenchone | Tubes / Valves | 10 | 14th July 2006 04:04 PM |
| testing unknown transformers | cm961 | Parts | 2 | 9th January 2004 04:56 AM |
| Page generated in 0.07758 seconds (70.99% PHP - 29.01% MySQL) with 10 queries |
