| diyAudio Sponsor | ||
Ok I have an Audionics BA150 that has a problem. At start up there is an audible hum present. This is at warm up of which I thought there wasn't any b+ voltage present. Here is a schematic of the amp....
Any ideas?Schematic |
#3 |
Hum does not go away with warm up. It does get a little lower but not much. As for voltages I'm not sure I just tested tubes, sockets ect.
#4 |
The power supply electrolytic caps are also well past their use-by date. I'd replace them (they were Mallory CGS, if memory serves). Check also that all grounds are tight and not affected by corrosion.
This was a very cool amp with innovative design. I'm glad to see that there's still a few around.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
I will double check all grounds ect. Also the bias led's are supposed to flicker as the bias is adjusted. Mine are a solid light which according to the manual indicates tube or circuit failure. The signal sounds fine and the tubes appear to operate within their specs, I'll check voltages tonight.
#6 |
Definitely check the idle current. If it's acting the way you describe, the autobias circuit may have failed, or possibly the emitter follower screen drivers, more likely the former.
| For Sale: 2 Fosgate Audionics FG4200 Power Amps | jtieman | Swap Meet | 1 | 9th March 2009 03:23 PM |
| Page generated in 0.07038 seconds (74.78% PHP - 25.22% MySQL) with 10 queries |
