diyAudio Sponsor
Old 4th March 2007, 11:29 PM   #1
jarthel is offline jarthel  Australia
Default what 8-pin tubes would you suggest for an aikido preamp?
as title. thank you
not sure if this is relevant but: as for operating B+ voltage and such, should I use the table provided my mr. broskie? (there's a table of listed tubes with different B+ and resistor values somewhere in the site)
thank you.
Old 5th March 2007, 12:05 AM   #2
Tweeker is offline Tweeker  United States
Source, available B+ and are you using his PCB? How much gain do you need? If you uss 2 of the same tube and wire yourself, heater to cathode insulation issues can be solved by cross coupling (the tops in one tube, the bottoms in the other) and higher voltages used. Many octal tubes would like more than 150V anode.
If using not his values some will have to be derived yourself, which shouldnt be too big a deal.
Blog 64 has the biggest table of values I found there.
Be sure your foil hat has a good low impedance ground.
Old 5th March 2007, 12:47 AM   #3
An dual cross coupled Aikido example, from Sylvania 6SN7GTA data.
B+=517V, rk=1,100, r15=77.7k. Gives a current around 7.5ma. mu=19.5 and rp= 8,250ohms. V anode=250.
This gives a Zo of ~1,490 ohms and a gain of ~9.1. Very low distortion. Heaters floated at 30 and 280 volts.
Old 5th March 2007, 10:54 PM   #4
thank you
suggest about 9002/vt202 preamp please jp74 Tubes / Valves 0 1st June 2009 07:17 AM
Preamp suggest, please. kacernator Tubes / Valves 18 27th February 2008 07:29 PM
Aikido Tubes 2KW Tubes / Valves 47 13th July 2007 12:16 AM
Suggest a preamp for cd/tuner BeerCan Tubes / Valves 2 16th June 2005 12:14 PM
Please suggest a preamp HiFiNutNut Solid State 5 28th May 2004 06:08 PM
Page generated in 0.07271 seconds (71.62% PHP - 28.38% MySQL) with 10 queries
