| diyAudio Sponsor | ||
i was just cuious what order an amp sound be retubed in.
assuming it was set up with fresh NOS quality tubes in the first place, would the first to fade/affect performance be the rectifier tube, signal or power tubes. what about delaying replacement, would that put extra strain on transformers or other components? |
#2 |
The "usual" pattern is power tubes having the shortest life, small signal tubes living longer, and rectifiers living very long. It's common for a Mullard made GZ34/5AR4 to serve for 20 years.
Eli D. |
#3 |
if you neglect replacement of power tubes will it shorten signal rectifier tube life? really bad for transformers etc?
#4 |
The sound will suffer if a tube gets weak, but the rest of the unit won't. If a tube SHORTS, it might take out a transformer... hopefully a fuse will protect things though. A worn-out rectifier will sometimes flash over... but others usually weaken gradually.
#5 |
cool thnx.. always wondered.
| Quicksilver Retube | lpd | Tubes / Valves | 1 | 13th May 2008 01:32 AM |
| 1st order Passive Line Level Crossover + 2nd order Highpass? | alexclaber | Multi-Way | 11 | 4th January 2008 07:15 PM |
| deceptive perception ? 1st order-2nd order question | poldus | Multi-Way | 4 | 10th April 2007 11:58 PM |
| 1st Order Tweeter, 3rd Order Woofer? | Jay | Multi-Way | 8 | 8th May 2004 09:29 PM |
| 1st order ? L-R 2nd order? or transient perfect?? | Ken L | Multi-Way | 6 | 17th October 2003 04:22 PM |
| Page generated in 0.08606 seconds (72.17% PHP - 27.83% MySQL) with 10 queries |
