| diyAudio Sponsor | ||
I am collecting some parts to begin working on an Aikido preamp using John Broskie's boards. I am leaning towards going with 6CG7's for the input and 6922's or 6H30's for the output based on some positive posts I found on this combo and as I can get some of these tubes pretty reasonably priced.
I have looked at the designs posted at tubecad for power supplies, but I am still pretty much a noob and would prefer to use a PCB for this as well to prevent issues and speed up the assembly. Does anyone have a good source for a nice PCB which would allow a 6.3v heater and 200-300v b+ output required for the Aikido? Also if any of you have a parts list for an Aikido which worked well please post it here, I am getting dizzy looking at all the different types and values of components as well. |
#2 |
bump
#3 |
There's actually not that many choices out there if you insist on regulation. There's jackinnj's:
http://tech-diy.com/DIY_PWR_LastPass.htm I don't know of one specifically for regulated heaters, but you should be able to find something intended for SS that will fit the bill because it is low voltage.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
#5 | |
#6 | |
http://db.audioasylum.com/cgi/m.mpl?...an&r=&session= |
| FS: 24v Aikido PCB, PSU, and misc parts | jrebman | Swap Meet | 1 | 11th December 2008 11:15 AM |
| Aikido Amp Parts (amp + custom PS) | n_maher | Swap Meet | 5 | 1st March 2008 01:53 PM |
| Maida Regulator Parts | Eli Duttman | Tubes / Valves | 6 | 2nd June 2007 12:56 PM |
| PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! | marioinla | Swap Meet | 1 | 31st August 2004 04:22 PM |
| Parts source for M.Hubers P.S. regulator? | mwmitchell | Tubes / Valves | 4 | 23rd June 2003 12:53 AM |
| Page generated in 0.10590 seconds (70.87% PHP - 29.13% MySQL) with 10 queries |
