diyAudio Sponsor
Old 3rd March 2007, 08:36 PM   #1
Default A heater wiring DOH! moment??
Hello Folks. I am working on a new SE amp. Problems with the 6.3V heaters. I measure 3.2V at each pin (both socket and pin). Neither the 6SJ7's nor the KT88's heat up. What is my DOH??
Should I be grounding the CT or should it float?
MG
Old 3rd March 2007, 09:23 PM   #2
w5jag is offline w5jag  United States
You didn't by chance use the 230V primary on a 230/115V dual primary transformer, did you?
I would think you would want the center tap grounded, but just disconnect your filament string from the transformer, ground the center tap, and see if that gives you the voltage you expect.
Win W5JAG
Old 3rd March 2007, 09:45 PM   #3
I have the 5V rectifier and B+ I expect. The 6.3V heaters are CT and the CT is grounded.
I think perhaps I have a faulty heater supply. One lead reads 3.2V, the other .33V referenced to ground.
Darn.
MG
Old 4th March 2007, 09:27 AM   #4
Zibi is offline Zibi  Poland
If the transformer is good, one of the filament wire is probably shorted to the ground.
Old 4th March 2007, 10:31 AM   #5
Alastair E's Avatar
Sounds to me like the centre-tap is wired out of phase, IF you measure 3.2V at each heater pin with the ct earthed.........
reverse one half of the 6.3V secondary heater winding, and all should be well....
Das Beste Oder Nichts
Heater wiring help! losacco Tubes / Valves 1 23rd May 2009 08:33 PM
1st Project Heater Wiring cgrums Tubes / Valves 14 24th August 2007 07:03 PM
!2ax7 heater wiring? Series / parallel? glaznost45 Tubes / Valves 1 27th February 2006 11:51 AM
heater wiring tenderland Tubes / Valves 6 2nd March 2005 08:14 PM
Page generated in 0.07310 seconds (79.81% PHP - 20.19% MySQL) with 10 queries
