diyAudio Sponsor
Old 2nd March 2007, 05:34 PM   #11
Interesting topic. While I don't have anything to add (my knowledge is limited...), I would like to see a schematic. I've wanted to make an 807 sort of amp for a while now...
Old 3rd March 2007, 12:08 AM   #12
To all the members who are trying to help me sort out this problem I hope I can manage to post these 2 partial scans showing the screen grid VR section.
As can be seen, from a B+ of around 450V there is a 10K/10W dropper resistor feeding 2 VRs for 250V - an OC3 and OD3 - which is then taken to the 807 screen grid via a smaller 1K0. (Is this a grid leak dropper similar to that used for the signal grid in audio amplifiers?) There is then a 47uF/0.22uF capacitor combo from the 807 screen grids to earth (ground). I'm not sure if Kevin is referring to this capacitance.
I now realise that by halving the 1K0 resistor I didn't change the current draw of the VRs. Maybe, I need to lower the 10K resistor. Perhaps, you guys can guide me as to the value to use. The real B+ voltage is rather lower than that specified due to the slightly lower secondary AC voltage rating of the transformer I used.
I hope this gives you a better idea what I'm talking about.
Thanks and regards to ALL.
Joe A
Old 3rd March 2007, 12:13 AM   #13
kevinkr's Avatar
HMMM, I'm not sure about that 47uF cap and the combination of VR tubes through a 1K resistor, but presumably other amps based on this design do work.. The 10 K resistor would result in a total VR tube + screen current of 20mA which may be rather marginal at full power - I would decrease that resistor to say 6.8K and see what happens.
www.kta-hifi.net
Old 3rd March 2007, 08:22 AM   #14
Hopefully I get the image posted this time.
Old 3rd March 2007, 08:22 AM   #15
This is the second part showing how the VR supply is connected to the screen grid. The member who asked me for the 807 circuit can email me directly as I'm still being 'moderated'...
FOR TUBE: 350V High Voltage Regulator uhcmos Swap Meet 26 6th February 2010 05:28 AM
FOR TUBE: 350V High Voltage Regulator uhcmos Tubes / Valves 0 31st May 2008 12:49 PM
tube voltage regulator error amp nhuwar Tubes / Valves 14 20th May 2008 11:38 PM
Tube Voltage Regulator Design CarlyBoy Tubes / Valves 61 30th October 2006 04:31 PM
Tube for a shunt voltage regulator jarthel Tubes / Valves 14 26th October 2006 05:19 AM
Page generated in 0.07906 seconds (80.04% PHP - 19.96% MySQL) with 11 queries
