Projects...How does one decide ?
Old 25th May 2007, 05:26 AM   #11
jduffy is offline jduffy  United States
jduffy's Avatar
I'm still crazy new at this and have been bumbling along but enjoying the ride.
I started with a kit integrated amp, then some full range speakers, then a guitar amp from a kit, a guitar from a kit, then a preamp from scratch using a schematic I found on the net, then refurbed a pair of old speakers which was really fun, and finally finishing up a tube phono pre right now.
Currently I'm considering another amp but this time monoblocks. Have found some nice ideas here in the forums.
I haven't followed a plan per se but have been building the component I thought I needed the most, next. I'm really happy with what I've built and refurbed so far. DIY makes audio much more interesting.
Good luck with your choice(s).
Old 25th May 2007, 07:40 AM   #12
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Default Re: Projects...How does one decide ?
Originally posted by Steven-H
All,
How do you all decide what project to move onto next ??? I mean; besides the obvious "Wow - that's a cool looking tube !", or "Well, I always did want an SET", how do you go about it ?
What I find interesting. That usually involves trying out designs with non-"audiphool" VTs, especially the much maligned TV t00bz, quite a few of which are outstanding audio performers. Much cheaper than those 2A3s and 300Bs, etc that are frequently used instead.
For example, I always liked the 807's from a looks standpoint - but Im not sure about their audio prowess.
If there's a better audio final out there, I sure haven't heard of it.
Ditto for the 829's.
Dunnow 'bout that one.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 28th May 2007, 07:11 PM   #13
richwalters is offline richwalters
richwalters's Avatar
Steve
During the late 1950's I remember when the EL34's were suddenly in short supply and a raft of quitar amps appeared on the market with 807's in 30W p-p o/p stages which with lower Ra-a, sounded way better. Anyone with tubes would immediately spot the RF equivalent of the 6L6 which it is. 807's pressed into real audio service can give 50W p-p but at this stage the 6550 series is better suited.
I find the EL34 a good tube but far, far too soft on the uppers, even on guitar... Everyone agree ?
The 807 is legendary in it's own element, like a 6L6 tame as a cat.
richj
Old 28th May 2007, 07:30 PM   #14
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Now I have a heap of tubes of various kinds and also a some transformers, so I try to optimize by putting together a certain tube with a certain transformer. I have to look at power voltage and current ratings and of course the "imponator factor" of the tubes - a 829 is better that EL84 for instance.
I also try to find a sort of balance between look of tube and OP-power and simplicity of design.
This list which contains maybe seven future projects is constantly changes as I either get new tubes, nwe components of other type or get an design that looks interesting.
The projects that are "planned" for the future are the 6B4G-PP, 807-SE, 6P43P (like EL84) -PP, 829-SE, 832-PP, 6L6-PP, 6P36S-??
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 29th May 2007, 03:02 AM   #15
ak_47_boy is offline ak_47_boy  Canada
I find i like just building bench circuits, rarely actually putting it all in a chassis. Fun experimenting with overdriving, feedback etc.
Projects...How does one decide ?Hide this!Advertise here!
Help me decide what to build! Emprov Multi-Way 1 25th March 2008 04:12 AM
Help Me Pick Projects, I Can't Decide ??? kvk Everything Else 5 25th February 2008 09:22 PM
OB or TL - Help me decide jim rose Full Range 13 22nd March 2007 10:10 AM
Help me decide on an OP-amp Cradle22 Parts 16 25th April 2005 05:31 PM
Copyright ©1999-2017 diyAudio
