diyAudio Sponsor
Old 27th February 2007, 01:29 PM   #1
arvin is offline arvin  United Kingdom
Default Converting a yarland amp to drive headphones
I have a yarland 34c iii amp and want to drive a pair of akg headphones (impedance 32 or 64 ohms), using the speaker terminals.
Can I just connect a resitive divider bridge at the output terminals, to reduce the power? How can I do this?
please advise
Converting Yarland FV-34AIII to Triode and Zero NF jolon Tubes / Valves 4 11th January 2012 04:11 PM
single tube to drive 300ohm headphones sunrise Tubes / Valves 26 10th March 2009 12:09 PM
Portable direct drive amplifier for ESL headphones shyfx Solid State 6 11th May 2004 10:54 PM
How to use a PIC I/O audio square wave to drive headphones ransom peek Solid State 5 2nd December 2003 10:49 AM
Can BOZ Drive Headphones? vdi_nenna Pass Labs 22 17th September 2001 02:14 AM
Page generated in 0.05831 seconds (64.14% PHP - 35.86% MySQL) with 10 queries
