| diyAudio Sponsor | ||
The power output -about 20W but could be increased without problems but what is the best compromise to achieve...let's say 35-40W?
I want some opinions in this: http://www.audiodesignguide.com/my/pp3.html What do you think?
"I'm glad I can build my own mistakes." |
#2 |
That will be complicated, and the complication will get you only a very small increase in perceived volume. The problem is that paralleling tubes (which you'd need to do to double the power) doubles the Miller capacitance. The transformer won't like that. It can be circumvented by interposing another stage to buffer the output stage grids, but that is not trivial.
My advice: don't sweat the extra 2-3dB if you're heppy with that amp. If you want more power, start with a fresh design.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Higher B+ ?
320V seems much lower than most EL34 / KT88 I have seen. SveinB |
#4 |
That's pretty normal for class A or rich AB operation. If you raise the B+ and readjust the cathode resistor, you might squeeze another watt or two out at the expense of linearity. The difference between 18 and 20 watts is zip.
Basically, 20W is about the most to expect from trioded EL34, and even that is pushing it. KT88 might give you 30, again, barely noticeable power increase but you'd have to change the output transformer.
#5 |
What do you think about that?
4 x KT88 per channel 480v 80ma per tubes LL1627/PP (2300ohm/8ohm) same input circuit Rk(ohm) = 150 Ck(uF) = 1000uF or better 6 x EL34 per channel 470v 50ma per tubes LL1627/PP (2300ohm / 8ohm) same input circuit Rk(ohm) = 150 Ck(uF) = 1000 What about Miller effect?
#7 | |
The E182CC driver has a rp of ~2k at 20mA so I suppose it’s able to feed some Miller capacitance, even through a (step up) transformer. Reflected primary capacitance at 1:2 step up and 4 x 100pF tubes: Cprim = (Csec)*(2/1)^2 = (4*100pF)*4 = 1600pF F-3dB = 1/(2pi C rp) = 1/(2pi * 1600p * 2k) = ~50kHz. Jan E Veiset
Life is hard - Then you die. |
#8 |
You are tending to forget that the interstage transformer is likely to have its own capacitance to bring to the mix which is likely to make your 50Khz estimate very optimistic. Interstagers are hard beasts to drive at the best of times and a significant element of the driver stages capacity will be taken up simple with dealing with that.
Also if you try to get things to operate a bit more into AB, the driver is going to start to crumble big time. It strikes me that this design is optimised for the components and trying to extract more power from it will likely end in failure. Shoog |
#9 |
Of course the 50kHz is optimistic, and it does not reflect the real circuit (the LL1660 transformer has a bandwidth of ~35kHz etc). It just tells something about the contribution of the transformed Miller capacitance, seen from the driver’s point of view.
Jan E Veiset
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.12168 seconds (79.60% PHP - 20.40% MySQL) with 11 queries |
