Some trouble reading schematics
Old 14th January 2003, 09:58 PM   #51
Joel is offline Joel  United States
Joel's Avatar
Kristijan,
It's still wrong. With 160V in, and a choke in series, there is no way you're going to get 210V.
Probably around 150V or even less would be more realistic.
Old 14th January 2003, 10:05 PM   #52
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default MARK III
Yes,185 VAC would come close.
Frank
Old 14th January 2003, 10:56 PM   #53
kristijan-k is offline kristijan-k  Croatia
Hello,
Thanks guys.
But, that way it was appeared in Glass Audio, and it is designed
by well respected Mr.Erno Borbely.
Old 14th January 2003, 11:03 PM   #54
fdegrove's Avatar
Default MATH.
Even when disregarding the choke you would at best get 220 VDC at the output.
Add the choke and the load to the equation and you'll see the PSU voltage drop.
Even the best make mistakes (I may be one of them )
Frank
Old 14th January 2003, 11:56 PM   #55
fragman56 is offline fragman56
Default 8-10W SE for $200
Hey Shifty,
I would be interested in seeing a schematic on this. Would this budget include all parts purchased?
Thanks,
Rick
Old 15th January 2003, 01:18 AM   #56
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
OK, try a SET 6B4 (2a3 with 6V filament) and assume some access to scavenged/used stuff...
(Prices from triodeelectronics.com and others)
2x sovtek 6B4G $59.95
2x sovtek 6SN7 $19.90
2x Hammond 125ESE $70.00
Scavenged power tranny & choke & chassis, diode rectifier...
Various other parts (resistors & caps) ~$50
Hey presto! cheap and choice. And about 8W, you can run the sovtek 2a3/6B4 at 30W dissipation quite happily. I can't find my favourite 2a3 schematic at the moment, but there are a lot around.
You don't need to spend thousands to build something good.
Some trouble reading schematicsHide this!Advertise here!
Need help reading a pot from an old amp clintp Parts 1 19th May 2009 10:33 AM
Need help reading cap flatpicker Parts 2 7th January 2008 07:44 PM
Trouble Reading Blueprints For Fostex Recommended Enclosure kelticwizard Multi-Way 2 13th April 2007 04:18 AM
About CD reading Sandor Digital Source 3 8th January 2006 02:59 AM
Some reading ... sobazz Multi-Way 0 25th January 2004 11:47 AM
Copyright ©1999-2017 diyAudio
