| diyAudio Sponsor | ||
Why isn't it used more? I was just going through my tube stash and decided to finally look up these things. Turns out the tube is a dual triode, dc coupled internally. It requires no biasing and input grid is at 0 volts but doesn't draw a current. Gain is 58 and output is 4 watts into 7K load. Unfortunately, I can't find curves on the tube.
Anybody have experience with these? Looks like input can be R or rc coupled and you just wire a transformer in series with the tube and connect the cathode to B-. |
#2 |
Not sure if I trust an unlabeled set of curves:
http://simpletube.com/zboard/zboard....sc=asc&no=2521 |
| need great smd cap for audio application | jsaggio | Parts | 1 | 11th September 2007 03:41 AM |
| great DIY tube and DAC stuff | Lagroute | Swap Meet | 10 | 13th December 2006 09:06 PM |
| How do you finance A Great DIY Audio Amp? | Trout | Tubes / Valves | 2 | 7th August 2006 04:12 PM |
| Page generated in 0.06341 seconds (69.54% PHP - 30.46% MySQL) with 10 queries |
