diyAudio Sponsor
Old 23rd February 2007, 07:21 PM   #1
Question 12B4 Equivalents?
Are there any 12B4(A) equivalents or close substitutes among the European tubes? Looked at the usual on-line references but none are listed... Hard to believe that this is a unique design
Thanks!
Old 23rd February 2007, 10:01 PM   #2
Zibi is offline Zibi  Poland
6s19p ?
Old 23rd February 2007, 10:33 PM   #3
Really? At the first glance there seem to be more differences than similarities
Old 23rd February 2007, 10:35 PM   #4
diesel_tech's Avatar
Send a message via MSN to diesel_tech
how bout a 6877
Old 23rd February 2007, 10:52 PM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
In the US, triodes (such as 12B4) were used for TV vertical deflection. In Europe, pentodes were the norm for TV vertical deflection, hence no European equivalent.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th February 2007, 12:22 AM   #6
hi Valverine,
do U use it for driver tube?? is the 6S4 suitable?
thx
thomas
Old 24th February 2007, 05:43 AM   #7
Tube-lover is right. Tell us what are you looking for. A direct replacement or just single triode for particular purposes.
Old 24th February 2007, 05:35 PM   #8
Thanks for the replies!
I'm contemplating using 12B4 in the output position of an Aikido pre. Required params are low internal resistance and good anode current - in this respect 6S19P and other small regulators will fit, as well as 5687, 6N6P, 6N30P.
Based on the prev. discussions here it seems that some 12B4 incarnations might be somewhat problematic, hence the desire to expand the base for the selection.
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... Mark A. Gulbrandsen Tubes / Valves 789 8th March 2011 12:04 AM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 06:06 PM
Page generated in 0.08991 seconds (72.93% PHP - 27.07% MySQL) with 10 queries
