diyAudio Sponsor
Old 23rd February 2007, 11:24 AM   #1
Default Kt88pp triode controlgrid resistor ????
Hi
I have a problem.
I have a china amp that i am modding.
It is a williamson copy, but with Kt88 pp as triode and fixed bias.
The second grid have a 2k7 2w to the anode.
Why that big value. Is there a way to calculate that resistor.
B+ is 430 v.
Thanks for reading.
Soren
Old 23rd February 2007, 04:19 PM   #2
Tubes4e4's Avatar
Hi Soren,
when converting a tetrode, pentode or beam power valve as in the case of KT88, to triode, the screen grid stopper resistor should be chosen in values as low as possible, while maintaining that no parasitic oscillation takes place. In your case, a resistor in the range of 100 to 270 ohms should do nicely (but make sure that there are no parasitics anyway).
If you want to learn more on how to convert tetrodes and pentodes back to triode operation correctly, you might have a look at this script.
Tom
If in doubt, just measure.
Old 23rd February 2007, 04:39 PM   #3
Thank you Tom.
/Soren
Old 24th February 2007, 03:00 PM   #4
Can you please tell me, why the g2 resistor have to be 2w type.
Soren
Overdriving the grid of a triode MadDave12 Tubes / Valves 24 10th December 2011 08:40 PM
KT88/6550 as Triode Ardee Tubes / Valves 11 9th October 2006 03:33 PM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 01:59 AM
Grid driven (ETM) KT88 SE amp design - final works on paper Vortex Tubes / Valves 49 13th June 2004 12:04 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Page generated in 0.09493 seconds (59.90% PHP - 40.10% MySQL) with 10 queries
