diyAudio Sponsor
Old 22nd February 2007, 04:29 PM   #1
angelfj is offline angelfj  United States
angelfj's Avatar
Default 866A transient over-current capability?
I am beginning to assemble the B+ PSU for the AlumRocksClone. I would like to use the Caps and chokes I have on hand. problem is that with a choke input, there is a transient that exceeds the 1.0 amp maximum of my 866A's. See attached. Can these tubes take the abuse or must I select a smaller Cap size? Is there a way to soft-start the PSU to attenuate the peak of the transient?
Thanks in advance.
Frank
Old 22nd February 2007, 08:09 PM   #2
Dave Cigna's Avatar
Default Re: 866A transient over-current capability?
Yeah, a variac.
January 20, 2009: Bush's last day
Old 22nd February 2007, 08:17 PM   #3
angelfj's Avatar
Dave: Seriously? I can see doing this with a prototype, but what about the finished product? During a future senior moment I might forget to reset the variac.
Old 22nd February 2007, 08:32 PM   #4
sorenj07's Avatar
It will probably be fine. Current doesn't start being drawn until tubes warm up, and besides, the "soft start" option doesn't model this slow increase of drawn current. Not to mention that it probably takes a lot longer than 1 second for the 866's to warm up...
Old 22nd February 2007, 08:45 PM   #5
tubelab.com's Avatar
866 type tubes must have the heater voltage applied and the mercury allowed to vaporize before anode voltage is applied. The data sheet specifies this warm up time as 30 seconds minimum. Violators are often rewarded with a tube arc which can really ruin your day if you use electrolytic caps.
If you can live without the cool blue glow use a 3B28 rectifier instead of the 866. No toxic mercury, no RF noise, no warm up time. Drop in replacement.
To soften the initial turn on surge, put an "inrush current limiter" device in series with the transformer primary. I used a CL70 but you may need a different size depending on total current. Search DigiKey for the specs.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 22nd February 2007, 09:11 PM   #6
Tweeker is offline Tweeker  United States
If this amp does not have a dead constant current draw, the PSU from that PSUD II pic has lots of resonances that will bite you. Try a stepped load and see.
Be sure your foil hat has a good low impedance ground.
Old 22nd February 2007, 09:38 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I can't believe the ESR of your capacitors is really as high as 5 Ohms. 10H is probably too small for such a high voltage supply. Check your choke current too.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd February 2007, 10:11 PM   #8
Capacitor ESR could be fairly high if its a string of electrolytics in series. Though 47uF makes no sense then.
This supply is 1250-0-1250? If so I get 90ma peak AC current with a 10H choke. VACRMS/(1386*H)= peak ac choke current @ 60hz.
Old 22nd February 2007, 10:21 PM   #9
agent.5 is offline agent.5  United States
Originally posted by tubelab.com
[B]866 type tubes must have the heater voltage applied and the mercury allowed to vaporize before anode voltage is applied. The data sheet specifies this warm up time as 30 seconds minimum.
Yes. Use a delay relay and separate filament supplies for the 866A. 866A has lower DCR than 3B28.
Old 23rd February 2007, 12:51 AM   #10
Hey-Hey!!!,
My RCA data sheet for the 866A shows a 2A maximum current for up to 2500 PIV. You're very near that, so I would be careful about warming them up before applying the HV. that same sheet also gives a 500 mA max, averaged over a 30 second period( so a pair can deliver 1A of DC ).
I plan to try a pair of 866's with a filter that runs 1.3A peaks at SS conditions. They should glow very nicely...
cheers,
Douglas
the Tnuctipun will return
866a Min operating voltages timothyldodd Tubes / Valves 10 12th September 2007 01:18 PM
filter circuit for 866a Masami Tubes / Valves 3 24th June 2004 07:49 PM
Mu-follower current capability? Fuling Tubes / Valves 5 5th May 2004 10:37 AM
866A tubes WALTER BURKHARD Swap Meet 0 27th June 2003 02:07 PM
Page generated in 0.10907 seconds (82.99% PHP - 17.01% MySQL) with 10 queries
