diyAudio Sponsor
Old 22nd February 2007, 06:21 AM   #1
Default Broken Tube pin guides
I was able to get some SV6550C tubes from a friend . It was stored for a long time and was known working before storage. The pin guides are broken and also noticed a hairline scratch/crack . Is it safe to plug in the tubes ? What is the consequence if i plug it in ? .. will it explode .. spoil some parts of the circuitry .. or spoil my speaker ?
cheers
Old 22nd February 2007, 06:56 AM   #2
Geek's Avatar
If the glass is cracked, it could shatter when it heats up. If it's just a scratch, not too much worries. Your getter flash looks good, so a crack is unlikely.
Do run for say an hour in an uninhabited area so if it does fracture, people or pets aren't injured. Just to be safe.
Broken index, no problem. Just make sure the "slot" is lined up between pins 1 and 8.
Cheers!
Old 22nd February 2007, 04:02 PM   #3
Thanks for reply . It may be a slight scratch but not really penetrated the glass as the getter flash still clear.
Too bad it is a great tube ( C-winged Svetlana ) .. but i think i'd rather replace it for safety.
Old 22nd February 2007, 04:54 PM   #4
Trout is offline Trout  United States
Trout's Avatar
If Its not cracked, and your worried about not having a guide pin.
Antique Electronic supply sells a nice little replacement guide pin that slides on over the metal pins.
http://www.tubesandmore.com/
Its located under Vacumm Tube Accesories / Adapters.
Not cheap, but handy.
Trout
crossover guides morfic Multi-Way 6 28th August 2009 09:32 PM
Will magnet grill guides affect the esl? CharlieM Planars & Exotics 11 17th January 2009 09:53 PM
Broken 6L6WXT tube Sal Brisindi Tubes / Valves 6 12th March 2007 04:33 AM
WTB: CHEAP tube amp. Broken/single channel/whatever. Spasticteapot Swap Meet 4 25th October 2006 11:51 PM
IC guides/beginner projects AndersJ Parts 8 8th October 2006 06:30 PM
Page generated in 0.07611 seconds (69.69% PHP - 30.31% MySQL) with 10 queries
