diyAudio Sponsor
Old 21st February 2007, 03:28 PM   #1
hags is offline hags  United States
Default 6DJ8 or 12AT7
Looking for opinions on and experieinces with choosing between the 6DJ8 and 12AT7, particularly in a driver circuit. I'm leaning towards the 6DJ8 for voltage gain and splitter.
Thanks.
Old 21st February 2007, 03:33 PM   #2
SY's Avatar
How much voltage do you want to swing? What sort of configuration?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st February 2007, 11:50 PM   #3
not sure, still hunting for the best idea, either a cascode gain circuit or used in a long tailed pair splitter circuit.
I hear pros and cons for each, most seem personal preference not performance specs.
Old 22nd February 2007, 06:54 AM   #4
frugal-phile(tm)
planet10's Avatar
What are you trying to drive?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd February 2007, 12:16 PM   #5
SY's Avatar
I've done extensive work with both those tubes in driver circuits and have lots of measurements on both. Each has its use and virtue.
The ECC88 has a lower mu, lower Miller capacitance, higher transconductance, and generally needs higher current. The 12AT7 has double the gain, takes a higher rail voltage, and has better linearity in grounded cathode at large voltage swings. So, once you decide what sort of splitter you want and what you need it to do, the tube choice can be rationally made.
Ecc81 12at7 316a Swap Meet 0 30th May 2008 11:51 AM
12at7 LTP CCS wicked1 Tubes / Valves 11 23rd April 2008 08:28 AM
6V6 ->EL84 with 12AT7? zxx123 Tubes / Valves 8 5th April 2006 06:12 PM
Can I use 12AT7? Ahmad_tbp Tubes / Valves 6 25th January 2006 06:11 AM
Page generated in 0.08083 seconds (68.98% PHP - 31.02% MySQL) with 10 queries
