| diyAudio Sponsor | ||
#11 | |
#12 |
For the Machine with 5AR4 rectification, I use (if Hammond) the 372FX. I put a little (27ohms) resistance in series with the plates to take it easy on everything, and 6.8 or 8.2uF for the first cap before the (5H) choke. Cap on the output is 120uF. Onward to the input supply.
Anybody wants a schem, say so. Aloha, Poinz |
#13 |
Are Hammond Power transformers made in Canda?
I took mine apart and it looked like it was made in China. All my 27XX series run real hot, would never use them again. Art |
#14 | |
I have been puting them in SE amps (worst case for continuous current drain) for about 5 years. My latest amp has only been running for about 4 months. I am now drawing over 200 mA from a 150 mA rated (at 50 Hz) transformer (I changed tubes to EH KT88's and they sound best when run hot). It is often left on for hours at a time. Yes it gets hot, you don't want to hold you hand on it kind of hot. I should really change out the transformer for a bigger one, but I am considering this a "stress test". I will change it out if it blows up, this amp has the nicest chassis that I have done yet and I don't want to mess it up. It is already too crowded.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Question about current ratings of Hammond 300 series power transformers. | G | Tubes / Valves | 14 | 4th April 2009 05:38 AM |
| Hammond Power Transformer Buzz... | Guiness | Tubes / Valves | 29 | 28th June 2008 12:51 AM |
| Help with wiring a Hammond Power Transformer | wonsup | Tubes / Valves | 3 | 7th January 2008 01:07 PM |
| Hammond 300BX Power Transformer | SPWONG | Tubes / Valves | 0 | 24th October 2003 03:10 PM |
| Quality of Hammond 300 series power transformers compared to 200 series? | G | Tubes / Valves | 8 | 21st September 2003 02:27 PM |
| Page generated in 0.07785 seconds (71.46% PHP - 28.54% MySQL) with 10 queries |
