| diyAudio Sponsor | ||
Could anyone recommend a tube based Moving Coil head amp schematic for me to build? Preferably something simple based on the 6922 or similar.
Has anyone built such a beast? When I build a head amp do I put it between the player and the phono stage or do I hook it into the regular line amp stage? I have a Rega 2 with a Sony XL-MC1 hooked to a modified PAS3 type preamp. There is just not enough gain to sound anything close to reasonable. Even when I swap out the 5751 tubes for 12AX7s there is not much of a change. Thanks in advance, I have never been disappointed in the knowledge given here. |
#2 |
You might want to check out the first stage of Allen Wright's preamps. www.vacuumstate.com
If I were to use a 6922/E88CC family tube, I would definitely use a step-up transformer if the solid state bit of Allen's design scares you.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 |
Try a pair of CineMag CMQEE-3440A Step up transformers:
http://db.audioasylum.com/cgi/m.mpl?...ag&r=&session= There are others using these for low output MC's, just search the Vinyl Asylum. I just may give them a try myself. Jeff |
#4 |
Those do look pretty interesting. Definitely simplifies things, no power or anything. I could put them right in my Pas3 and run a set of separate inputs to them.
I will do a bit more searching on them and see what luck people have had with them. Thanks! |
| PS Audio Moving Coil Amplifier (MCA) Schematic | AnalolgAlley | Analogue Source | 6 | 21st April 2007 12:35 AM |
| Moving coil meter: where to buy? | Thoru | Parts | 4 | 3rd January 2006 04:28 PM |
| moving coil loading | lt cdr data | Analogue Source | 28 | 27th June 2005 10:50 PM |
| Page generated in 0.07714 seconds (69.94% PHP - 30.06% MySQL) with 10 queries |
