diyAudio Sponsor
Old 20th February 2007, 12:32 AM   #1
jkeny is offline jkeny  Ireland
Banned
Default Triode Trick
Has anybody tried this trick to convert pentode to triode operation ala Bill Perkins from Pearl Inc and shown here: http://t-linespeakers.org/tubes/triode-trick.html
This seems to be an alternative to ultralinear operation - am i right?
Any impressions?
John
Old 20th February 2007, 02:12 AM   #2
Tweeker is offline Tweeker  United States
Only insofar as triode connection is an alternative to UL operation. Its an alternative to a ~100 ohm resistor.
Be sure your foil hat has a good low impedance ground.
Old 20th February 2007, 07:42 AM   #3
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default yes
the reports are that this solution sounds better than a resistor.
Old 20th February 2007, 07:50 AM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
An alternative to UL connection is not what is intended here. All he is saying is, if you want to connect a pentode/tetrode as a triode, it's better to do it his way. The arguments make sense to me, but how much better it will sound I wouldn't know.
Old 20th February 2007, 08:25 AM   #5
Geek's Avatar
That's also known as "boosted triode".
You'll also see that used on some Lafayette and Hallicrafter tubed CB radios on the RF final.
Old 20th February 2007, 09:22 AM   #6
Banned
Ah! now that I know the name for it I can find past refernces to it in here.
I had a quick search and found refs but nobody seems to have tried it and reported on the sonics. I'm only new to tubes & seem to be ploughing the same furrow many have before - Have I missed something?
John
Old 27th February 2007, 10:27 AM   #7
Luanak is offline Luanak  Spain
I have tried a similar aproach. But I do it with a programable tl431
shunt regulator at around 25V , with a Elna 450uf cap across it.
The power is a little bit smaller, but the sound is bit better to me, more relaxed or open.
Cosme
Old 27th February 2007, 11:51 AM   #8
Klimon is offline Klimon  Belgium
I've incorporated this 'trick' in my el84 se and must say that it makes an excellent improvement. My grievances before the mod were a somewhat slow, romantic but also muddled sound lacking attack; after the mod the amp sounds much more detailed and tighter. I wouldn't consider building another triode-strapped amp without using the trick. BTW the schematic contains a few small errors, ask me if you're really interested than I'll take a peek into my amp and see how I did it. fwiw Eddie Vaughn made a few suggestions for optimising the circuit (he uses something similar in his carina), namely using 5,6V zeners IIRC (same number would do the job) + one 1000µF electrolytic instead of the two 470µ and resistors. He also explains the benefits on his website (think he calls it black box).
Simon
Old 27th February 2007, 01:23 PM   #9
Default TRIODE TRICK
Simon,
What are the few small errors in the schematic ?
Bien à vous .
Robert
Old 27th February 2007, 02:08 PM   #10
Banned
Hey Cosme,
I would be interested in a schematic for the tl431 version if that was possible?
Simon,
Ditto with your corrected schematic - would love to hear more.
John
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
Pentode to Triode trick. Diy martin Tubes / Valves 4 7th November 2005 11:00 AM
It's not a trick, it's a Philips. Bernhard Digital Source 6 2nd April 2004 10:17 PM
Page generated in 0.10305 seconds (76.27% PHP - 23.73% MySQL) with 11 queries
