diyAudio Sponsor
Old 19th February 2007, 05:50 PM   #1
boudy is offline boudy  United States
Default 9 pin replacement sockets
Hey,
I'm looking for oversized 9 pin sockets for an old console amp. The openings are 1" diameter and the spacing of the mounting holes are 1 5/16". The existing sockets are wafer type.
The size of the existing openings preclude the use of standard sockets with 1 1/8" spaced mounting holes.
These sockets are for 12ax7 and 6bq5 tubes.
I've already checked several online suppliers and eBay.
If there aren't suitable replacments available then I may plug the existing holes and put in the standard sockets. However this is a good deal of extra work, I'd prefer to find sockets that will work with the chassis as it is if possible.
I'd appreciate any suggestions.
Thanks.
-Eric
Old 19th February 2007, 07:35 PM   #2
Bottlehead sells some "hole shrinkers" that may or may not work- i'm not sure of the exact dimensions but you could email them.
http://www.bottlehead.com/et/parts/parts.htm
SMD/DIP Converter Sockets AudioFox Parts 5 26th October 2008 06:58 AM
DAC on 16 pin DIP sockets dip16dac Digital Source 1 19th May 2004 01:10 AM
Removable TO-220 - Sockets Super_BQ Pass Labs 8 30th November 2003 09:46 PM
WTB UX5 sockets bcherry Swap Meet 0 1st March 2003 02:24 PM
RCA sockets carlmart Parts 8 31st January 2003 10:21 PM
Page generated in 0.06686 seconds (68.57% PHP - 31.43% MySQL) with 10 queries
