I have some 5654
I have some 5654
Old 18th February 2007, 05:31 PM   #1
Hojvaelde is offline Hojvaelde  Denmark
Default I have some 5654
Hello
I have found some 5654
I can see 5654 is a low noise pentode.
I am planning a preamplifier with RIAA input. Can I use those tubes and if yes, does any have a schematic with 5654.
Benny
Old 18th February 2007, 07:19 PM   #2
On Hiatus
SY's Avatar
I have some 5654
A pentode will not be the last word in low noise. Whether giving up a few microvolts is worth it for some of the pentode virtues (especially regarding gain and Miller capacitance) is a much more subjective matter.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th February 2007, 07:23 PM   #3
the_manta is offline the_manta  Germany
the_manta's Avatar
5654 / EF95 / 6AK5W are bulk goods here in Germany. But nearly all of mine are very microphonic. So be carefull that you have good ones.
Simon
Old 22nd February 2007, 04:29 PM   #4
Brian Beck is offline Brian Beck  United States
Brian Beck's Avatar
I also have a number of 5654/6AK5/EF95 tubes, pulled from RF equipment. Given that these are sharp cut-off rather than remote cut-off devices, they stand a fighting chance of making fairly linear triodes, which is how youíd wire them for lowest noise, as SY says. I havenít tried them for audio, but they just might be worthwhile. The transconductance in pentode configuration is about 5000 uS at the data sheet bias values. With the screen tied to plate, that value would increase to over 6000 uS, a decently high value. Of course a 6DJ8 can double that value, but transconductance isnít everything. The triode mu of a 6AK5 is around 20, going by memory, which might be wrong. Often, for the first stage of RIAA, youíd want a bit more gain to increase the noise figure, but a medium mu tube is still a possibility depending upon your other circuit choices. I believe that triode-wired 6AK5s were used happily in some tube microphones, but factors like physical size and heater power requirements might have also influenced those choices. Why not give it a try and let us know how it worked?
Brian
I have some 5654Hide this!Advertise here!
Tube Buffer 6J1 / 5654 (6AK5) Cobra2 Tubes / Valves 104 9th April 2016 06:39 PM
6ak5/5654 plate resistance rauze Tubes / Valves 7 17th September 2008 03:28 AM
