| diyAudio Sponsor | ||
Banned
Hi all,
I've searched but didn't find a thread covering this: Where can parts be salvaged and how can they be used in amps (or other). I thought it would be good to gather together all suggestions into one thread for all frugiphiles and cheapskates like myself. I got my current tube amp (Rogers Cadet III) from a recycling centre - the output stage of which I have rebuilt into a Gingertube "baby huey" at no cost. In the past I had desolder some high voltage caps from TV circuits, etc before disposing of the pcb. As I was not a tubes guy I had no immediate use for them but they came in useful in above amp. I have heard that caps and chokes from Microwave ovens can be used - could somebody detail where they are most applicable. I have also seen mention of ballast chokes in fluorescent lights being useful - again could somebody detail where applicable. Finally, mention is often made of motor run capacitors - I presume these are not used in cars but in electric motors - so there goes my idea of picking them up at car salvage yards - wher are these usually found? I downloaded an article recently (and posted about it here) detailing how to convert a PC smps into a hig voltage output PS suitable for B+ tube PS. Any other areas where cheap (free) parts might be obtained? All this appeals to me on two fronts - usually free or at least very cheap and also the green party aspect of it all. John |
#2 |
Magneto the Gravity Man
I always salvage things that look useful.
The big box marked 'that will come it handy someday!'. Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
I would suggest a recyling place/scrap yard
they buy non-working chassis's and sell as either Steel or Aluminum breakage and I have found wonderfull transformers on these units. And they will normally sell you all by the pound/ or for you KG. I know quite a few people who buy these tube chassis and salvage the american tube sockets and the tubes as well.... Steve @ Apex Jr. |
#4 | |
Andy
#5 |
Your neighbor's trash container.
Minimal effort, maximum return. Loads of Japiton devices of beauty in stuff which most throw away.
Looks like Sponge Bob has killed another thread. |
#6 |
Banned
As I said in my first post, I found the Rogers Cadet III amp(fully working) in a recycling centre.
In the past I have also found 3*Samson Servo 250 pro audio amps 250 watt (good sound but I got them for parts - large heatsink, large EI trafo, 8*2SC5200 trannies & complimentary trannies, 2*10000uF 80V Sawha(?) capacitors. I also picked up a Rega Planar 2 turntable - old model with S shaped Lustre(?) arm - fully working except for belt - replaced with rubber band - seems to work well - need more time to listen. So far, recycling centres have been good to me although the staff don't like you to take away more than you are dropping off - I tend to ignore their protestations seeing as I pay €7 every time I want to bring in my car with material to be recycled. Any other suggestions for equipment to look out for which have recyclable parts? John |
#7 |
For the motor-run capactors, try abandoned trailer parks, farms, etc., where they have a deep well water system, I've seen these on pump controls. Also (but not sure, and HVAC outdoor unit or pool pump system). Also for relays, octal sockets, etc., try old gas stations/convenience stores, as a lot of times their gas pumps use some of this hardware.
#8 |
john, I tried some of the recycling places here and the gits wouldn't allow me take stuff away (the mind boggles!)
3 phase motors here run on 380V - might be a source (that I hadn't thought of up to now) of caps. I think theres a difference though in motor run and motor start caps (although 3 phase mightn't need those, not sure). These motors are chucked out all over the place as they are very cheap to buy. Fran |
#9 | |
#10 |
Banned
Fran,
As you are taking stuff for recycling out of the car bring what you want back to the car (so what if you are leaving with more than you brought) - I don't get questioned when I do this. The one and only time I asked I was refused - so I ignore them now. What are three phase motors used for - how would I recognise one? Jackinnj, we don't have tornados (or trailer parks) in this part of the world, maybe this is a good thing John |
| Salvage component from an old amp ? | NyxOne | Chip Amps | 9 | 26th July 2011 11:31 AM |
| Salvage value? | Mark2727 | Class D | 9 | 13th April 2009 05:32 PM |
| Parts Salvage | jkeny | Digital Source | 2 | 21st April 2006 04:10 PM |
| Opinions on salvage parts | fortuosity | Parts | 6 | 17th September 2005 02:06 PM |
| Can I salvage this component? | TheDarkside | Parts | 1 | 13th November 2004 04:59 PM |
| Page generated in 0.10866 seconds (85.42% PHP - 14.58% MySQL) with 11 queries |
