power supply question.... too many Volts?
Old 17th February 2007, 06:52 PM   #1
akimball442 is offline akimball442  United States
Send a message via AIM to akimball442
Default power supply question.... too many Volts?
I have two amplifiers i am concerned with in this post... one is an eico ST70, the other is an old motorola amp.
I would like to run both with less tubes, as stereo power amplifiers only. I'm wondering if removing tubes is going to create too much of a rise in voltage, and throw things out of whack?
The ST70 would be lacking only 4 preamp tubes in this configuration. I don't imagine that would be a huge problem.
The motorola however, is a 3 channel 6bm8 amp which has a total of 4 output tubes, the bass is a PP mono setup, the R/L channels are single ended. I want to use this amp with only the pair of single ended tubes. I think that might be more significant.
Any ideas? Should I worry about adding resistors?
Aaron
Old 18th February 2007, 06:16 AM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
I doubt that it will amke much difference if the PS was designed to have anywhere near a reasonable regulation. Even if the voltage rises somewhat, remember, VT circuits are a good deal more "forgiving" than SS.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 18th February 2007, 02:55 PM   #3
Klimon is offline Klimon  Belgium
If you want to keep close to the original design (= not using it as a parts donor) I would suggest to measure B+ voltages and current draw for the SE output stages, then redesign the power supply (reusing the original trafo and possibly chokes / caps) using Duncan's PSUDII simulator (can be downloaded on duncanamps.com) which is an excellent tool + easy to work with.
edit: the single-ended opts will probably lack low-end bandwith if they were designed to work together with a dedicated low-end PP amp.
good luck!
Simon
Old 18th February 2007, 05:12 PM   #4
the OPTs for the single ended outputs on the motorola are lousy, but I have a pair from another amp which are much larger.
power supply question.... too many Volts?Hide this!Advertise here!
Negative volts and grounding in bench power supply falcott Parts 11 29th April 2011 04:42 PM
how to use 30 volts DC instead of split power Supply ali_moinuddin Pass Labs 5 2nd April 2008 11:34 PM
16 volts 3A regulated power supply help sunny Power Supplies 30 3rd November 2006 12:51 AM
Volts AC rating in power supply caps rick57 Parts 6 28th May 2006 01:59 AM
How to use a 220 Volt power supply at 12 Volts in the car? Mr. Old School Car Audio 3 10th March 2006 01:11 AM
Copyright ©1999-2017 diyAudio
