problems with 805 tubes
Old 16th February 2007, 05:07 PM   #1
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Default problems with 805 tubes
I have had the worst luck with 805 tubes. The first pair I got were direct from china, and one was blown. The second pair I got cost me 80 dollars, came from a US Tube distributor, but were also the Chinese Sheguang tubes, and the metal "hats" fell off. The Epoxy, or whatever it used to attach them, came undone from the heat. I then ordered a second pair from China, the new version with Ceramic Insulators. I plug them in, it blows a fuse, one of the 805's is bad. I can't seem to get a decent set of 805's at a reasonable price. I could pay 350-400 dollars for the Valve art 805's, which are Chinese, but I guess of higher quality. I could look for a set of NOS RCA's or GE's, or whatever, but I seem them so rarely, and they also go for quite a bit. Anyone got any ideas here. I would not have thought that the 805 tube was such a pain in the butt.
One I dea I had was to take a pair of the good 805's and use a conductive epoxy to resecure the hats. It should work, and at least I know the tubes are good. I wish I could have some with the thermal isolator like the new ones I ordered.
Old 17th February 2007, 03:27 AM   #2
bear is offline bear
expert in tautology
bear's Avatar
You probably can't use conductive or any other sort of epoxy on the plate caps.
Most epoxies can't handle the envelope temperature.
You need either "lamp cement" which is what is normally used on vacuum tubes or some other sort of high temperature "adhesive". Both can be had, although you'll have to do some research to make that happen.
I don't happen to have either myself... fyi.
I'd contact the seller, and see if they'll make good on the bad tube(s).
_-_- bear
PS. you do know the 805 is a zero bias class B tube?
For SE operation, an 845 or 211 is likely preferable.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 17th February 2007, 03:33 AM   #3
On Hiatus
SY's Avatar
Try Electrotemp Cement No. 8 from Sauereisen.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th February 2007, 04:45 AM   #4
thanks, I'm really getting sick of these tubes. I mean, when working they sound great, but they don't last, and I have currently 6 tubes and 2 good ones. None of them are matched, not that its all that important, but the two good ones don't even look alike. Anyway, thanks, I will look for that cement.
Old 31st July 2007, 02:27 PM   #5
nhuwar is offline nhuwar  United States
nhuwar's Avatar
SY do you know of any place that sells that cement. I have tryed to use Sauereisen in the past but could not find a reseller. Sauereisen has a very high minimium order if you order directly from the company.
Nick
Old 31st July 2007, 03:12 PM   #6
On Hiatus
SY's Avatar
Have you called them to ask about distributors? I haven't bought any in years.
edit: It looks like McMaster-Carr has some similar stuff listed under "refractory cement."
Old 31st July 2007, 03:46 PM   #7
nhuwar's Avatar
Ya I've tried the stuff from crack master it's not bad. I called Sauereisen and ask about reseller and they wouldn't say, they wanted me to deal directly with them.
Nick
Old 31st July 2007, 03:50 PM   #8
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Use nailpolish
If you can see the speaker cone move...it's not hifi.
Old 31st July 2007, 03:51 PM   #9
nhuwar's Avatar
Nail polish No way it will get brittle way to fast from the heat
Nick
Old 31st July 2007, 03:54 PM   #10
Maybe on the top of an 805 tube it will.
But not on the base of a rectifier tube or 300B....works like a charm. Got the tip from: Tube Lore by Ludwell Sibley"
"Loose Bases.
To re-cement the tube, use clear nail polish - paint a ring around the base, let the polish soak into the old cement, recoat, and let dry overnight. Polystyrene "coil dope" works as well, and can be used to refill the nail-polish bottle.
Solvent (acetone, etc.) are ineffective in softening the old base cement - the cement was baked hard in manufacture, and "nothing" dissolves it.
problems with 805 tubesHide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 10:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 01:37 AM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 12:26 PM
Experiencing problems to insert tubes talaerts Tubes / Valves 6 29th January 2007 07:38 PM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 10:22 AM
