| diyAudio Sponsor | ||
After sarching around for some time, just gathering info, I've decided to do something tubewise for myself.
I have been reparing /servicing tube eqpt. for many years, so I don't expect any serious problems from a strictly practical point of view. For the time being, I'm not in for a lot of experiments. I want to make something with a decent result, for starters, and as "therapy" from other chores. The experiments will have to come later, when I have more time. I've decided for something around 40-60 W or so.. don't need much more..... I found this one, which looked interesting http://www.jogis-roehrenbude.de/Lese...uanleitung.htm which is closely related to this one http://www.jogis-roehrenbude.de/Vers...ommes/GU50.htm I think I'll stick to EL/KT tubes tho' - mainly for reasons of easy supply. But then there's a lot of them out there, ---lots of various topologies. As for OPTs, Lundahl and Hammond are within easy reach.. The output part is fairly easy, but what about the input / splitter part?? Concertina, CCS etc. etc. Any thoughts about better/worse, characteristics...?? My mains experiences with tube amps, are mostly applications where linearity and distortion are not major factors.... |
#2 |
It's an adaption of a good 1960 circuit, but the 6SN7 is not a great candidate for cascoding. These days we can do better, especially regarding the balance of the phase splitter.
For a KT-series tube, you'll need on the order of 30-40VRMS drive, which can be best achieved by cascaded constant-current-tail diff amps, or something like a Williamson. If you're adventurous and open-minded, try using a well-wound 1: 1+1 input transformer to get the signal balanced right from the get-go, then use diff amps the rest of the way through.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Just one thing bothering me in the given GU50 amplifier circuit: Surely R12 and R13 cannot be only 22K? That will give a highly unsatisfactory load to the phase inverter. I would believe that to be a misprint for 220K, but such a value would somewhat exceed the maximum specified for fixed bias operation of the power tubes.
Perhaps phase splitter anode loads of 47K/56K working into 100K grid resistors? Mmmmmm...
#4 | |
diyAudio Moderator Emeritus
#5 | |
cyrilic GU isn't
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#6 |
This GU50 is evidently some russian / east German pentode type, which I will not use, mainly for supply reasons, - even if it might be good. I will most certainly stick to some El or KT, - or something very close.
Edit: BTW- the referred german article says tteh GU50 is russian copy of af a "Wehrmacht" type LS50, also known as a former East German tube SRS 552...... Even if there are a few variations, like straight pentode, UL, triode strap etc, the actual output stage is fairly straight forward. Some issues about choosing the correct anode impedance load, perhaps. The difficulties seems to be in choosing the input/splitter circuit, and this is where I seek the advice. A few months back, I felt like going for a classical Dynaco Mk-III, which I know from a rather famous scandinavian PA setup from way-back-when, but surely something must have happened in the tube world in 40 years??? Any possible links to proven circuits that are reputably better than the Mk-III ?? |
#7 |
Ray,
So what is that doing in the reference of the Grommes 260 or whatever? And I cannot even blame it on my knowledge of German! I am now retiring to bed (it is about 2:00 in the am here) and shall take a stiff brandy to try drown my inferiority feelings. Yours liquorly. |
#8 | |
Mahogany and brass will be my choice of materials when I start building!! Come to think of it---Does anybody know anything about these Grommes amps??? Yours liquorly..... ( I just found some Scotch in my innermost cabinet corner |
#9 |
AuroraB,
Just before drowning the sorrows inflicted by Ray, I cannot now access a particular circuit, but I have been using a pentode input directly coupled to a Schmitt (long-tailed pair), much like the given circuit, for years (decades) now. As you said, there are no particular outstanding circuits, but I found that very reliable and capable of low distortion, though you mentioned that that was not too important. I hesitate to tout my own circuits around, but could put something on here in the morning that I have used. But others will probably oblige with references; there are many very suitable circuits in this category. Regards. |
| Possible group buy of Lundahl input/phase splitter transformers. | Shoog | Tubes / Valves | 51 | 14th November 2008 11:45 AM |
| Phase Splitter as input stage | Peter Menting | Tubes / Valves | 21 | 3rd January 2005 08:48 AM |
| VGA splitter | Rookie | Parts | 1 | 17th September 2004 03:54 PM |
| MC input topology: transformers or active stages? | mrfeedback | Analogue Source | 29 | 20th September 2002 10:17 PM |
| Page generated in 0.10720 seconds (86.96% PHP - 13.04% MySQL) with 11 queries |
