| diyAudio Sponsor | ||
Are there any considerations I should be aware of using DHTs and cathode feedback? The filament transformer will be non-decoupled in the signal path -- any chances for capacitive or inductive coupling between the push and pull side or strange frequency response?
At the schematic a filament transformer, with two center-tapped windings, is connected to x-ct-x and y-ct-y. ![]() Jan E Veiset
Life is hard - Then you die. |
#2 |
Jan, what software do you use to make those nice schematics ?
Mike |
#3 |
When I tried the same trick with 2A3 (didn't work very well), I used a transformer kit to make the 2A3 heater windings. The significance is that it was a split bobbin construction with the primary in one half and the other half left empty for the secondary. Thus, there was very low capacitance between the mains and the 2.5V 2A3 heater windings. You might want to consider the same idea here.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 | |
What went wrong with the 2A3s? (@mobyd: I'm using MS Visio) Jan
#5 |
I think it was a poor output transformer. The moment I saw it I had my doubts - the winding window wasn't full. Anyway, trying to add cathode feedback (same proportion as yours) ruined the square wave response even though it reduced distortion.
#6 |
Not so much gain available with DHT triodes, to use cathode feedback!
Most of them are already hard to drive, and increasing drive signal increases drive stage distortion. So, what's worse? I've tried with 300B, and they become unity-gain devices Linear, but useless. |
#7 | |
![]() Jan E Veiset
#8 |
How much power will you expect?
#9 |
About 2x15W
Jan.
#10 |
Hi Jan, a somewhat off-topic suggestion. I've been playing around with bias points for the triode-mode 6CW5/EL86, subbing for an EL84 in SE. At very near the operating conditions you're using the 3rd harmonic distortion component of NEC-branded version drops dramatically, multiple tens of dBs. I recall the plate current was more high teens than low twenties, otherwise plate load and B+ were near identical. You may be able to significantly better that 0.1% with an EL86 and get lower source impedance to boot. To my ear it also has a much more direct sound than the EL84.
| Cathode Feedback from Secondary for PP Amp | gingertube | Tubes / Valves | 22 | 1st July 2009 11:45 PM |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 08:07 PM |
| Cathode Feedback How-To? | sorenj07 | Tubes / Valves | 4 | 23rd October 2007 05:04 AM |
| DHTs and Cathode Bias | 6f6 | Tubes / Valves | 4 | 28th March 2007 11:40 PM |
| Cathode feedback | mark_titano | Tubes / Valves | 20 | 11th August 2005 01:56 AM |
| Page generated in 0.10980 seconds (78.27% PHP - 21.73% MySQL) with 10 queries |
