diyAudio Sponsor
Old 15th February 2007, 01:41 PM   #31
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Thats not bad.
This is what I use but I dont own it
http://www.bpt.com/index.asp?pageID=63&prodID=56
But I dont have one at home yet I was thinking of buying that combination unit.
Nick
Old 15th February 2007, 03:22 PM   #32
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Oh, man... oh man. Lucky you. That is the best of the best.
I started learning machining out of frustration simillar to Engels. I got small lathe and mill/drill. Made some improvements by installing VFD and thre phase motor and DROs
Machining is art on its own, once you go into it - it is beautifull. After initial learning, I just started making something - a big amp case. Here is the picture of the top grills that I just completed.
There are some more pics in this tread:
Treshold Stasis S300 Vs Aleph 30
When I started learning I was completly clueless (not much better now ether) and there is a lot to learn, but what a pleasure making something in metal. Unfortunatelly this craft/art of manual machining is disapearing and is replaced by CNC. But as a result of that and availability of cheap chinese machines it is getting easier to go into as hobby.
Stay well
AR2
PS Now I now whom to bother for machinning tips.
Old 15th February 2007, 04:48 PM   #33
nhuwar's Avatar
Also have a small hardinge and a large nardini engine lathe and a surface grinder almost a full machine shop. I also have the equipment to put mirror finishes on metal.
Nick
Cutting IEC Socket in Chassis reaper996 Chip Amps 25 30th January 2011 09:46 PM
Making plated through-hole PCB rozon Parts 2 1st May 2009 02:57 AM
Fs:neutrik Gold Plated Rca Socket Female Chassis - Free Shipping! YFW Swap Meet 0 24th August 2008 06:29 AM
help soldering ground wire to a Cardas female RCA chassis socket jarthel Parts 4 6th March 2007 02:23 PM
Larger chassis Hole Punches rick57 Tubes / Valves 36 10th July 2006 09:31 AM
Page generated in 0.06881 seconds (69.18% PHP - 30.82% MySQL) with 11 queries
