| diyAudio Sponsor | ||
I Am, doing chema from Le Bong with Preampli phono but have some quets about powersuply :
- With power vontage 12v, and 24v pass to C-R-C how com to B+ 100V, havefun
Like DIY audio ! http://www.linn-vn.com/ |
#2 |
Here:
#3 |
So sorry !
Here: Main power suply.
#4 |
I guess your original question was on the power supply, and that is shown in your last schema. What it does is that first they take a small supply built into a power mains plug (also called wall-wart) to make 15VAC, that they rectify and stabilise to 12VDC.
The same (unrectified) 15VAC is used to power another wall-wart in reverse, in other words they input the 15VAC into the output of the wall-wart, which actually is the secondary of its transformer. Then on the input of the wall-wart (actually the transformer primary) they take off about 120VAC. That can then be rectified etc for the 100 and/or 170VDC. But to built this amp you don't need to built THIS power supply! Anything giving the required voltages would do. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#5 |
Thanh for anser..and helping me..!
Now iam change Shema for new powersuply. Here :http://www.audiovnclub.net/forum/ind...e=post&id=7274 http://www.audiovnclub.net/forum/ind...e=post&id=7510 ......... And am thing good for my choice. ..File to big and am can not up to here, same like that: Powersuply : B+ with VAC 230V120ma not CT>Van12X4 danaco with 1/2 diot 14004 out CT, and 10mf 350V>choke 8H200ma >10mf 350V>R 7,5 K>220mf350V>R7,5K>220mf350V, and 150K for va. I'm thinh am don't want to follow powersuyply from that! and same I'm do here, you thinh good ? fo not good? for my ofjcetion? With H.. 12VAC not CT for ECC83, you thinh h use AC and DC? Because once time I'm DIY H with AC but OK for my Line preampli.
#6 |
And now Iam have to much Capacito ( Sangamo silvered ) From 10P come to 10,000,000P, may be mothan 100pc, but am dont no can use good for audio , of not?
Pleaser hepl me ! It there:
#7 |
Exacly my Email Hiendheaven@fpt.vn.
OK! Im soud you my Preampli nealy ok.
#8 |
Here my system .
Power mosfet SE IRF 150 monoblock mod from FL 99. Firt time Preampli use 1 802S.
#9 |
Full My system :
#10 |
New main phono 12AX7x2, 12AU7:
| Powersuply mystery | argo | Solid State | 6 | 10th May 2004 01:46 PM |
| 2 trannies on one powersuply | Per | Solid State | 15 | 10th October 2002 06:42 AM |
| Page generated in 0.12220 seconds (78.53% PHP - 21.47% MySQL) with 11 queries |
