Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 11th February 2007, 09:21 AM   #1
Nordic is offline Nordic
Nordic's Avatar
Default Cheap emergency gold sockets
Stole this idea from Sijosae.. so I better share it...
If you need a socket and the shop is closed...
pull the pins from an old female d-sub plug....
There you go, cheap gold contacts...
Old 11th February 2007, 11:44 AM   #2
Sonusthree's Avatar
Default Re: Cheap emergency gold sockets
Filed for future reference!!
These are the kind of tips that keep my projects rolling.
Cheers, Nordic.
Old 11th February 2007, 03:48 PM   #3
Tom Bavis's Avatar
I may never run out of miniature sockets (have plenty of salvaged ones) but recall that compactrons and Novar tubes have .040" (1 mm) pins as well...
Old 11th February 2007, 04:11 PM   #4
rdf is offline rdf
rdf's Avatar
I tried that waiting for acorn sockets to arrive and found the pins didn't retain tension well. A simple solution was slipping 1/8" of tight-fitting teflon sleeve over the sub-D pin before soldering, just enough to act as a tensioning band. Shrink tube might work too though not as well.
Old 11th February 2007, 04:16 PM   #5
Nordic's Avatar
But can you add an LED to the base ?
Old 11th February 2007, 05:16 PM   #6
Sonusthree's Avatar
You can't get away with that Nordic!!!
What is it? (Headphone amp?)
What tube is that?
What supply does it run in on?
How do I build it?
and .... I know it's so wrong ....... but I love the LED idea.
Old 11th February 2007, 06:08 PM   #7
Nordic's Avatar
Yeah, its a Multi-Hybrid Headphone Amp
6922 - ecc88 - 6dj8 and a few cheap fets and regs...
24V and 2 9V cells, batteryless version explained too.
http://translate.google.com/translat...language_tools
and another version
Old 13th February 2007, 08:10 PM   #8
Nordic's Avatar
Success... after some innitial headscratching
my second ever valve project... and the second cheveat was.... I am using my PC steering wheel's 24V walwart.
Tommorrow I wil build Sijosae's V3 of the same thing...
Old 13th February 2007, 08:17 PM   #9
Way too cool!
David,
When they pan a piano in stereo, I switch to mono... problem solved!
Old 13th February 2007, 08:19 PM   #10
Crusher
dsavitsk's Avatar
It might be worth pointing out that the pins on most pcb mount sockets do not line up with the pins on the tubes -- they are spaced wider. So, it looks like you designed the board with the eagle "tubes" library, and if you now try to fit a regular socket to the board, with a very few exceptions, it won't fit.
So, you may be stuck with the makeshift socket, and, importantly, someone with a board spaced for a socket who is lacking one likely won't get away with this trick.
Thread Tools
Emergency I'm dumb Chrism2sych Solid State 4 9th July 2009 10:25 AM
Emergency help with Wes' amp mashaffer Tubes / Valves 6 23rd May 2008 03:24 PM
emergency chip help! ThSpeakerDude88 Chip Amps 15 8th August 2005 06:18 AM
Page generated in 0.45488000 seconds (81.16% PHP - 18.84% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
