diyAudio Sponsor
Old 13th February 2007, 08:31 PM   #11
Nordic is offline Nordic  South Africa
Nordic's Avatar
Hi D. yes, am aware of it... V3 is so tight no socket would fit anyway... this one is just to listen to for a day or so and to build some courage...
very sentimental, but beats any chip headphone amp I've build in sound quality area... only tiny bit of hum... but then again look at my psu
real hybrid.... 9V cells, smps, j-fets, mosfets, tubes, and regulators
Old 14th February 2007, 04:01 PM   #12
diegot's Avatar
here is my one
just had finish the soldering job
i built the simple version because i cant find small pots here in my city.
regards
Old 15th February 2007, 03:21 AM   #13
Nordic's Avatar
Diegot, please send me a link for the pcb ... looking for that one... etched the V3, but it is rediculously small... have seen tubes with a larger footprint.
The one I built is very unstable... it oscilates on power on... gotta pull the tube and reinsert with the power running to fix... then you have to adjust the trimpots to make noise go away.
Then it sounds awesome I think the heatsinks on my IRF610s are too small... we are talking very hot.... Wonder if grid stoppers would help.
Old 15th February 2007, 08:51 PM   #14
diegot's Avatar
Nordic
I made the PCB of this link
http://www.headphoneamp.co.kr/bbs/zb...sijosae&no=247
Mine is rock solid. At the start up have a few seconds delay and then the sound starts. Very good but I have a little of hum, because i'm not using a regulated power supply yet. No grid sttopers required and it's pluged direct in the source, no volume control.
I just adjusted the trimpots just once, since then everything is fine.
I'm having 17V at the anodes but 7.3V at heaters, I need a larger resistor value on the 317.
At the output I'm using IRF530, wanna to try the 610 or 510 because their input capacitance, many times smaller than the 530, so I hope to get better treble.
The heatsinks are pulled of from a old At power supply and get real hot too, but I think that is fine for 2W of dissipation, I have two heatsinks.
Any problems you have I'm avaiable to help.
Diego
Old 16th February 2007, 11:59 AM   #15
Nordic's Avatar
Thanks, mine.....
still got to wire up pots... get new irf610s for the long legs, and then want to mount to base of CPU cooler...
Emergency I'm dumb Chrism2sych Solid State 4 9th July 2009 10:25 AM
Emergency help with Wes' amp mashaffer Tubes / Valves 6 23rd May 2008 03:24 PM
emergency chip help! ThSpeakerDude88 Chip Amps 15 8th August 2005 06:18 AM
Page generated in 0.07183 seconds (81.74% PHP - 18.26% MySQL) with 10 queries
