If you visit http://www.bluebellaudio.com/ and look at the tools section, you will see some fairly inexpensive hole punches (prices in UK£). Bluebell audio are based in Dundee, Scotland but most of their tools and hardware are supplied by Hammond, so you might want to check out your local Hammond dealer first.
I do it in AutoCAD and print it 1 to 1 then tape that to the chassis. Take a center punch and mark the centers of all the tubes and other holes through the paper template then you can remove it and make your holes.Kofi Annan said:Ciscokid,
What program did you use to make a printed layout of your chassis as a drilling template?
Kofi
