| diyAudio Sponsor | ||
Hi, I found in Internet that is possible connect 2 kt88 in class B and get 150 W. Do you know specifications about this connection ?
load impedance, B+, Vg2, Vg1, etc. Thank you |
#2 |
I looked on the data sheets found by Duncan Amp TDSL.
Listings were Class AB1 Between 50 and 100 Watts in Pentode / Beam Tetrode Mode. My Guess is for maximum power, you are going to be at or near maximum on both plate voltage, and G2 voltage of 800V and 600V respectively. The transformer primary impedance should be about double the class A Pentode Z. Guess of 6600 to 8000 Ohms would be optimum. Bias voltage would need to be determined, but it is very near cutoff on class B. The 625 / 600 V, 100W bias was -45 and Rl (a-a) was 5000 ohms GEC KT88 Data, Page 2 Hope this helps. Doug |
#3 |
Thank you DougL, I have a 9kohms primary impedance output transformer. First I will do the most simple. Vplate 800 V, Vscreen 400 V (I will take this V from the mid point of electrolitic caps in serie connection, the H.T. secondary have a mid point that I connect to the mid point of caps). I will tell you the results.
Thank you Juan. |
#4 |
GEC application report No.3 for KT88 Describes a 150W class B ICAS amp with 88's. (June 1972 issue3). The KT88 is config as triodes.
In brief B+ = 850V Vg2rms =60V Ia= 2x10mA Ia max sig = 2x140mA Ig1+g2=30mA Pout=150W RL A-A =6Kohms (speech applications) ICAS Zout =25Kohms D=6-8% Pdr approx=7W Vin (g-g)rms=360V Zin=18Kohms For other applications RL A-A be increased to 7.5Kohms. ( with B+ at 600V 100W is given) Driver stage must be capable of supplying 180+180V rms. The driver stage is a basic cathode biased using a centre tap feed choke of approx 20H < 500ohms. Small o/p tranny can be used as subs. I've got an article but it isn't fully complete. ICAS = Intermit Commercial & Amateur Service. There must be a full article somewhere on the web. richj |
| Kt88 Se | overdrajv | Tubes / Valves | 0 | 16th December 2008 12:26 PM |
| Help - CFB in a KT88 SE amp | Drewaudio | Tubes / Valves | 4 | 30th January 2007 04:36 AM |
| KT88 PP with Class-A/Class-AB switch | pingfloid | Tubes / Valves | 2 | 22nd January 2005 06:17 PM |
| Which KT88?? | Andy G | Tubes / Valves | 81 | 5th February 2004 07:48 AM |
| need to wire 2 kt88/6550 in class a mode! | richt | Tubes / Valves | 13 | 30th January 2002 03:46 AM |
| Page generated in 0.06059 seconds (84.23% PHP - 15.77% MySQL) with 10 queries |
