diyAudio Sponsor
Old 9th February 2007, 11:54 AM   #1
Send a message via AIM to JasonLee Send a message via MSN to JasonLee Send a message via Yahoo to JasonLee
Default Switching power supply for tube-pre
Just wondering if there is such design or may be it's already apply in some commercial tube DAC / CD plyaer.
I have bought some ECC83/12AX7 (NOS). But don't feel like buying a big transformer to build a pre-amp. What i was thinking is.. can i used some kind of power supply that samilar to CTV. Rectifier the AC direct from home socket. Throgh a switching circuit get 6.3V & 250V from the secondary of the switching transformer. Imagine that by doing so. It shall min the size of the conventional 50 Hz tranformer. Reservour cap also can be reduce in size. Will it works? All inputs are welcome.
Old 9th February 2007, 02:09 PM   #2
frank754's Avatar
This was discussed in another thread, you should always have some sort of isolation, never use the mains power directly and rectify it for the HV.
Here's a great inexpensive power transformer for a pre-amp, which I've used already. Very economical (under $15)
http://www.alliedelec.com/Search/Sea...B6A18043A0E17F
Another way that works well is two filament transformers back-to-back.
Here's something along these lines, for example:
http://www.lh-electric.4t.com/projects/budget_ps.htm
Old 9th February 2007, 02:11 PM   #3
SY's Avatar
Insanely dangerous for the home constructor without the ability to do proper double insulation. Don't even think about it.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 10th February 2007, 01:22 AM   #4
THanks, SY. But, I am not talking about rectify direct from 230 AC supply & used it as HT. What i am saying is.. build a something like PSU found in PC. Isolate the mains, make the swtching trans generate 6.3v for heater & 200v - 250v HT..
Old 10th February 2007, 01:31 AM   #5
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Just as long as you have the 230vac isolated because if you didn't and something went wrong 220 make an arc that look's like a fire it has no problem vaporizing 1\4 inch bolts I have seen it unfortunatly. I you ever come in contact with this or are doing a initial power up and adjustment and are close to the amp when this happens make no mistake you will be severly burned.
And If your eye's are close to the amp you will be blind and could possibly lose your eye's all together.
Rectified or not Isolate it THE DANGER is very real !!!!!
Just dont want to see anyone get hurt.
Nick
Old 10th February 2007, 01:31 AM   #6
SY's Avatar
Gotcha. Switching supplies in preamps have a long and honorable history. A buck/boost converter/reg for 200-300V is very doable. First commercial preamp I know that did this was the late 1970s Berning TF-10, followed by the late 1980s TF-12. The schematic might be of historic interest to you.
http://www.davidberning.com/tf-10.htm
http://www.davidberning.com/tf-12.htm
Old 10th February 2007, 01:34 AM   #7
nhuwar's Avatar
http://www.tb3.com/tesla/sparky.htm
This guy learned his lesson the hard way.
But he lived
Nick
Old 10th February 2007, 05:02 PM   #8
jkeny is offline jkeny  Ireland
Banned
Here's an article that describes exactly what you want -
"Regulated High-Voltage Supply For Valve Amplifiers
How to modify a surplus PC power supply to produce a 700V or 400V high-voltage rail"
You'll find it at:
http://www.siliconchip.com.au/cms/A_102096/article.html
Although it will cost $5 - still think of all the money saved on PTs.
I just downloaded it myself & am reading through.
Extract from article "The circuit is capable of excellent performance. It maintains full regulation at up to 125W, with ripple at 2V peak-to-peak, or 0.3% at full power. This is quite acceptable, as most of the ripple is at twice the switching frequency (60kHz) and so is inaudible.
The 100Hz hum component is only 0.08%, which shows the excellent regulation of the TL494, since the rectified mains source contains 13% of 100Hz ripple at full power. Over-current protection is retained, with a LED added to indicate when it is active. "
I believe it is safe - Would be interested in discussing it here. Here's the final schematic.
Old 13th February 2007, 02:38 AM   #9
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
A switching supply is definatly not worth it for a pre-amp since the transformers arn't big at all. However they could be ok for an power amplifier because when power dissapation gets large so do the magnetics.
Old 13th February 2007, 02:02 PM   #10
tubelab.com's Avatar
I tend to agree with this statement. The power transformer for a preamp is relatively small and cheap. The signal levels in a preamp are far lower than those in a power amp. The peak currents in a SMPS are far higher than those in a conventional power supply so it is harder to isolate the supply currents from the signal currents. An SMPS still has some 50/100 (60/120) Hz ripple as well as a lot of high frequency content. If this gets into the signal the amp just doesn't sound right. Do you want to chase hum, or hum and HF noise.
I have experimented with SMPS's for audio power amps with limited success. I have designed and built SMPS's for projects at work. I am about to travel down that road once again. This time it will be a completely digital design. Check this out:
http://www.microchip.com/stellent/id...param=en027097
The supply voltage can be modulated by the audio signal and a CCS function could be easilly implemented. SE parafeed without the choke.
A word of caution (don't ask me how I know this), in addition to the obvious electrical safety issues (use an isolation transformer for testing). Whenever working on any circuit connected directly to the line voltage, beware of the possibility that the circuit can explode violently with no warning. Even with a fuse at the input, there is enough energy stored in the capacitors to instantly varorize a mosfet. The resulting shrapnel is extremely hot. I place a thick piece of Lexan over the circuit before power up and keep a fire extinguisher nearby!
You must be prepared to sacrifice a few mosfets to the fire gods.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
K6 Switching Power Supply microsim444 Swap Meet 0 23rd November 2008 09:21 AM
Switching power supply for tube filaments possible??? noyan Tubes / Valves 12 17th September 2008 01:32 AM
Switching Power Supply? Apocarm Class D 9 2nd March 2006 05:02 PM
Switching 12V power supply PCB soundNERD Power Supplies 35 27th April 2005 01:35 AM
Page generated in 0.11344 seconds (79.51% PHP - 20.49% MySQL) with 11 queries
