Yes ... a dual channel please ... Kit or just a good diagram would do it. The KISS principle would hopefully apply ... although I would like to keep the phono pe-amp stage, but no need for tone, balance, etc, Prefered: 3 stereo inputs, for CD/DVD-A, Balanced AUX., PHONO ... balanced output?
FastEddy said:.............
(Wondering why these tube guys don't use torrid transformers in the power supplies ?)
because they are not better in preamp PSUs than good ole EI
Toroidals couple any high frequency power line hash from primary to secondary. This is difficult to filter out once in your power supply. This will lead to distortion of your signal as it is imposed on top of it.
EI's are poor at carrying high frequencies (this is why EI output transformers are so difficult to build and hence so expensive), and so the line hash never gets into your signal.
Shoog
Shoog
and passive pre-amp ? with trainnies ... S&B and if that is to expencive than similar trainnies from Sowter ... no active parts only input selector, wired with trannies and trannie secondaries are connected with the volume pot ... YOu can buy this thing under the name of Music First or Bent Audio or .... Promitheus is Far East option that costs no more than $350 (not very pretty though but it sounds very well).
Only an idea ...
Dejan
Only an idea ...
Dejan
" ... Toroidals couple any high frequency power line hash from primary to secondary. ... EI's are poor at carrying high frequencies ... and so the line hash never gets into your signal. ..."
Informative and to the point. Thanks ...
Is there a way to distinguish EI's (defination please?) of lesser quality or usability for the purposes of power supplies?
- Tubes / Valves
- Simple tube preamp?
