diyAudio Sponsor
Old 6th February 2007, 05:22 PM   #1
tubee is offline tubee  Netherlands
tubee's Avatar
Default AEG rectifier
I have here from old parts an AEG Rundfunk-Gleichrichter, (broadcasting-rectifier) coded B 250 C 125 L
B should be silicium 250 the voltage, 125 the mA's i think.
It is a black aluminium tube about 11 cm long, and 27mm diameter. Wires come out of bottom like a lytic cap. It has 4 terminals, 2 yellow (AC) and a red (+) and blue (minus)
Has anyone some info about this rectifier. How does it work (silicium, or mercury??) Might use it for a rectifier in a single 6922 line amplifier.
Daisy Bell
Old 6th February 2007, 05:44 PM   #2
ulibub is offline ulibub  France
If it is in a can like an electrolytic, than it is an old selenium bridge rectifier. They were often used during the fifties in radio sets.
You are right, B 250 C 125 means "bridge, 250 Volts, for capacitive load (C), 125 mA.
Greetings
Uli
Old 6th February 2007, 06:16 PM   #3
tubee's Avatar
Thanks Uli for reply
If its Selenium, (or maybe Germanium) how is performing in power supply compared to fast shottky like diodes?
Daisy Bell
Old 6th February 2007, 06:31 PM   #4
I am sure to 99% that it is Selenium. This was before the age of Germanium and Silicon in Europe, when only copper oxide (the flat aluminium cases) and Se (the colums with many disks, sometime built into a can, like yours) were used as semiconductors. I also have such old things still in my boxes....
Its performance - if you really want to compare it to "modern" diodes, and be it only a simple 1N4004, is almost - non existant.... Very high interior resistance, high voltage drop (easily 30-40 V), just like an old rectifier tube of the 30's... That time (in the 50's) it was an improvement - they needed no heating.
And they are incredibly slow and work only up to a few hundreds Hertz - so usable only for mains rectification. They also have a huge interior capacity.
So if you want to use it, do it for historical reasons - to keep the look of a historic set, or to show the working of an old technique. From an electrical point of view, I would forget them.
Uli
Old 6th February 2007, 08:45 PM   #5
tubee's Avatar
Thanks Uli for your clear reply. Will stack it in my garage again.
Daisy Bell
Old 6th February 2007, 10:44 PM   #6
It needs to go to a landfill that handles toxic waste. Selenium rectifiers are ticking time bombs. Sooner or later, they fail. When Selenium rectifiers fail, toxic vapor and toxic dust are produced.
Eli D.
Old 7th February 2007, 07:13 AM   #7
tubee's Avatar
Then i'll stack it in the other corner of my garage, with boxes of old medication, 486 and other pcb's, solvent containing paint leftovers, and replenisched oil to be recycled.
Daisy Bell
Old 7th February 2007, 08:05 AM   #8
Tweeker is offline Tweeker  United States
Put it next to the cyanide, its more toxic.
Be sure your foil hat has a good low impedance ground.
Old 7th February 2007, 08:15 AM   #9
tubee's Avatar
I wrapped it in aluminium foil, and stacked above the pcb's. Will recycle it soon, and tell the employee there its seriously toxic.
Daisy Bell
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
6CJ3 rectifier or 6D22S rectifier 56oval Tubes / Valves 10 19th April 2007 09:48 AM
81 Rectifier Diy martin Tubes / Valves 4 14th January 2006 01:54 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.09530 seconds (77.84% PHP - 22.16% MySQL) with 10 queries
