diyAudio Sponsor
Old 6th February 2007, 05:19 PM   #1
astouffer's Avatar
Default Gm emulator for calibration
Doing some searches about tube testers shows mention of someone using a "Gm emulator" for calibration instead of an actual tube. Anyone else ever tried this? It sounds like a FET or two and maybe some passive parts would be all thats needed.
Old 7th February 2007, 02:06 PM   #2
bembel is offline bembel  Europe
bembel's Avatar
Send a message via Yahoo to bembel
What tubetester model please ? Different patented topologies exists.
On Hickok transconductance meters, a isolation transformer with a variac are used to feed directly the tube pins , thus simulating a tube under test for calibration purpose.
Maybe this is your "Gm emulator" ?
Plus je pédale moins vite, moins j'avance plus vite !
Old 7th February 2007, 04:29 PM   #3
astouffer's Avatar
So its just an AC voltage thats applied to simulate a tubes Gm reading? This is the page that got me thinking.
http://item.express.ebay.com/Industr...mdZExpressItem
Old 7th February 2007, 05:10 PM   #4
Yvesm is offline Yvesm  France
Yvesm's Avatar
Me understand that they offer a service, not a product
Yves.
Old 7th February 2007, 06:50 PM   #5
bembel's Avatar
Astouffer
As Yves, I understand that they offer a "renewing & calibration" service. (helped by their own calibrated original test purpose tubes)
They also sell beside 5Y3GT(a) & 83 solid state replacement.
I wonder what's inside their 83 replacement, as I'm working on this project for a just found TV7/U, planned to be accurate & bulletproofed (I've yet worked on a digital readout like 120.0, & By now replaced the 83 by 2 TV damper diodes, with 2 150R res. But hope to find time to simulate something with zeners)
Prices seems fair...so far (If you don't like grease)
PS: yes it's just an AC voltage (IIRC at the most skilled calibration level)
Old 7th February 2007, 07:47 PM   #6
Brian Beck's Avatar
Astouffer,
I've heard of what you're asking about and have looked for one myself. Many tube analyzers needed a calibrated 6L6 for their own calibration, but I've heard of gm emulators too. I think it could be whipped up using an opamp plus a HV power FET to make a transconductance device whose gm would be set accurately by precision feedback resistors. You could use the AC heater supply to feed a small bipolar power supply for the opamp. It almost sounds like I'm close to drawing a schematic, doesn't it? If I have time, I may sketch something up. In the meantime, if you find something out there, let us know.
Brian
A Mic Calibration How-To cuibono Multi-Way 3 11th June 2009 11:10 AM
Emulator and programer for ATMEL MCUs Suoliang Swap Meet 2 24th September 2004 12:14 PM
Triode Emulator dimitri Solid State 9 1st July 2004 04:29 PM
tube sound emulator for pc moonshow Everything Else 5 4th August 2003 09:10 PM
Active crossover emulator and SPL meter in software FrankDIY Multi-Way 6 20th January 2003 02:45 AM
Page generated in 0.08714 seconds (75.23% PHP - 24.77% MySQL) with 10 queries
