| diyAudio Sponsor | ||
All,
I have tried to look at some data sheets in the last couple of days, but I haven't been able to find this answer.... What is the acceptable input cap value for Mercury Vapor rectifiers (Namely interested in the 83/816) to make it live a happy life ? Thanks ! Steve |
#2 |
hi,
IIRC it's less than 40µF with an input choke > 3H (for a 83) hope this helps.
Plus je pédale moins vite, moins j'avance plus vite ! |
#3 |
Zero. Hg rectifiers are intended for choke input because of their negative output resistance.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
Oops I was meaning 40µF after the >3H input choke.
sorry & thanks EC8010
#5 |
No apology necessary - I can't make myself as clearly understood in French as you can in English.
#6 |
those are explosive mistakes !
#7 |
Thanks Gents....This leads me to another question.
In looking here: http://www.diytube.com/st35/ST35_5AR4PS.pdf One can see the PSU arrangement. I will be subbing in an 83 tube, so by taking your recommendations I will be ditching C9, and increasing the choke to 5H or so. Any other changes ? I already have a timer delay circuit in place, so the preheating issues are taken care of. Secondly, the main cause for me asking this question is I wish to use a set of 816s in my PSU that will power my preamp/phonostage. I've been playing around with PSUd for a while, but I haven't been able to come up with anything too impressive. I guess I have a couple of issues; first one being that I am using an 83 tube to design the circuit; as PSUd doesn't have the 816 (But I believe it would be pretty close...). Secondly, I was planning on using a set of 0D3 regulator tubes; of which PSUd doesn't have as well. Do any of you have some tried and true suggestions ? Thanks again, Steve |
#8 |
Taking out the input cap from the power supply will drop your voltage by a LOT. instead of multiplying the transformer's AC voltage by root 2, you decrease it by 10%. Unless you have a much higher voltage power transformer than the one DIYTube specifies, you won't be able to use this schematic.
#9 |
Thanks.......So I suppose my option is now to either use a 450v or so transformer; or a 'normal' rectifier tube....
#10 |
Most spec sheets for the 83 mention operation with a capacitor input, typically with a min recommendation of 50 ohms total source impedance in series with each plate when using a 4 uF input cap. Why the big fat 'zero'?
| UCD 400 - Rectifiers | kephaudio | Class D | 1 | 21st May 2005 07:06 PM |
| Speaker size v Room size | cliffy | Multi-Way | 6 | 19th February 2005 08:34 AM |
| How many rectifiers? | Valverine | Tubes / Valves | 6 | 15th February 2004 03:00 AM |
| Page generated in 0.09599 seconds (78.94% PHP - 21.06% MySQL) with 10 queries |
